Is there a way to determine what the stall is of the TC?
Old Nov 27, 2001 | 12:44 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
A while ago, I had a tranny rebuild and the guy installed a NON-LU converter from what my Dad told me. Is there any way of finding out what the stall speed is of the TC?
2 Tickets to game= $250
Gas= $20
Sitting 20ft. from MJ= Priceless
'86 IROC T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK HEADERS Hooker CatBack
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Nov 27, 2001 | 01:54 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
The cheap way is to put your car in gear put your foot on the brake press the gas and see when according to the tach it starts to move the car.
Its not exact but its close.
SSC
85 Camaro Z28, Cowl induction hood, Black-355/TB400,3:42 posi, Tons of goodies but if you ask, "Its stock"
82 Firebird, White, red in six months-355/TB350,3:42 Powertrax posi. Not an insane amount of goodies but it runs like a motha!
76 Chevy C10, Firemist blue, 355/Muncie HD 3speed,3:73 TorqLine posi. Show me another 12sec@4800ft SBC street truck??
91 GMC 1500 Sierra 4x4, Red, Was 4.3 now the proud recipient of the Firebirds LG4. 305/5 speed.
56 Buick Special, OG Blue&White, V8/auto. Maybee one day I'll get it going.
Old Nov 27, 2001 | 01:56 PM
Car: 99 Formula
Axle/Gears: 342
Yeah, I saw that in summit, but it says it's not accurate. I might try it though.
Old Nov 27, 2001 | 02:56 PM
TheWraith's Avatar
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
just hold down your brake hard, and see how high you can get the rpms to go.
EDIT: i should add to do that in forward gear.
if you do that in neutral or park, it will redline obviously.
[This message has been edited by TheWraith (edited November 27, 2001).]
Old Nov 27, 2001 | 08:14 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The brakes will never be able to hold the car back enough to tell you how much the converter will stall at. You can try and get the flash rpm but that's all.
The only way to determine what the converter stalls at is with a transbrake. The transbrake engages first and reverse at the same time locking the transmission. The engine rpms can then be brought up until the converter stalls (rpms won't go any higher). When the transbrake is released at the converter stall speed, the hydraulic pressure is dumped from the reverse curcuit and the car launches forward like dropping a clutch at high rpm with a manual transmission.
Since each car is different, the stall speeds are also different. A converter that stalls at 2400 in your car may stall at 2800 in mine.
The current converter in my car is rated at 3800 rpm. I can only hold the car with the brakes to about 2400 before it starts creeping forward and I can't hold it any more.
To my knowledge there are no transbrakes available for the 700R4. It's only been less than 10 years now that they were available for TH350's. The rest of the driveline needs to be beefed up to handle a transbrake. Stock GM u-joints and the tiny 7.5" diff "may" survive one high rpm hit.
I'm going to a TH400 with a transbrake this winter. A 9" diff and driveshaft with 1350 u-joints will complete the driveline.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
amcnellis
Sep 16, 2015 04:16 PM
