Rearend Ratio???
Old Nov 21, 2001 | 07:16 AM
berlinetta85's Avatar
Rearend Ratio???
I've got an 89 Firebird Formula 350. I was wondering if anyone knows what rear gear ratio I have? I'm new to the scene and could use the help.
Old Nov 21, 2001 | 08:46 AM
82camaro's Avatar
Car: 82 camaro SC
https://www.thirdgen.org/newdesign/tech/techdb.shtml
2.77 or 3.27 depend on your options(it looks like the dual cat, higher horse engine got the 3.27 ratio
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Nov 21, 2001 | 02:37 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
<font face="Verdana, Arial" size="2">Originally posted by 82camaro:
</font>
as did some non dual-cat cars cause i have a single cat GTA, L98 with a 3.27 rear
*89 Trans Am GTA
*Moderator at www.transamgta.com
To hell with the GM vs Ford war. We must unite, as brothers to fight the plague that is overtaking the world...RICE
Tony
Old Nov 25, 2001 | 03:45 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
My '85 Z28 305 TPI (single cat, obviously) also had a 3.27 rear. You can determine your gear ratio by driving on the freeway in DRIVE if you have an automatic or whatever your 1:1 gear is in a manual. Drive at 70mph (I've heard other people say 65mph) and check your RPMs. If they are around 2700, you have a 2.73, if they are around 3200, you have a 3.27, etc...
Old Nov 25, 2001 | 05:01 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
70 MPH works for all the cars I have tested.
If you live in Southeastern US, check us out!
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
65MPH = 2100 RPMs for my 3:27
Old Nov 25, 2001 | 05:49 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
What tranny do you have and what gear are you in. You MUST be in the Direct Drive ratio (1:1) In a 700-R4 (4L60) its 3rd gear or "D". for a 5 speed, its 4th. It won't work in Overdrive "(D)"
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
Old Nov 28, 2001 | 06:07 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
2900 rpm @ 70 mph with my T5 in fourth, purple drive and white driven gears, 3.42 rear gears, 225/60R15 tires....
Pete
Pete's Place
HiOutput Tech Page
83 SC..former V6...now 216+k mile LG4/5-speed.. 14.891@95.54
Old Nov 28, 2001 | 06:19 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Ummm.... Skip all of that stuff and open your glove box (center console storage box deal), look at the Sevice Parts Information label (has all of the three digit RPO codes on it) and find the three digit codes that start with G. They are the ones for the rear axle. You should see G80 (limited slip differential) and either GW6 (3.27:1) or GH3 (2.77:1).
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
InfernalVortex
Apr 20, 2021 11:31 AM
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
