IT BROKE!
Old Aug 22, 2009 | 01:07 PM
Americanmouse's Avatar
Car: 1988 IROC-Z28
Engine: L98(383tpi) modified
Transmission: 700R4 rebuilt
Axle/Gears: 3:73 10bolt rebuilt
IT BROKE!
So what do you guys think it is?
Doing a hole shot at my work A.K.A.(showing off), something made a loud bang then no power at all. The car still runs, I can put it park, neautral, etc. But it won't go. I had the trans rebuilt, but the rear end is stock.
What do you guys think it is?
Old Aug 22, 2009 | 01:30 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: IT BROKE!
can you tell if the driveshaft is spinning? Its probably the rear
Old Aug 22, 2009 | 01:38 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: IT BROKE!
if he broke the rear it would still roll wouldnt it even in park since there's nothing holdin the teeth together like 86 said check to see if the driveshaft spins that'll help narrow it down
Old Aug 23, 2009 | 11:46 AM
Car: 1988 IROC-Z28
Re: IT BROKE!
I jacked the rear of the body up, and set it on jack stands onto the frame connectors. I then turned the tires on both sides in park, reverse, and drive. The driveshaft turns freely no hang ups. I then started it up with it still on the stands and shifted it into reverse and drive. Neither tire moves and the drive shaft does not turn. So I guess i broke my rebuilt trans.
Old Aug 24, 2009 | 05:57 PM
danandamy's Avatar
Car: 86 Camaro
Re: IT BROKE!
hmmm, I'm betting snapped an input shaft maybe.
Dan
Old Aug 24, 2009 | 06:13 PM
scamaro355's Avatar
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
Re: IT BROKE!
sorry to hear that....im not a fan of the 700r...mine lasted about 3 weeks after droppin 1500 in internal parts into it..just a weak tranny
Pac J
May 17, 2020 10:44 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
wanext
Oct 6, 2015 12:18 AM
bjpotter
Oct 4, 2015 07:48 PM
sjorgens
Oct 1, 2015 07:54 PM
