2.73 Rear to 3.73 Rear
Old Aug 26, 2009 | 05:40 PM
jmooreofpure's Avatar
What else do i need to upgrade on my 1990 Pontiac Firebird EFI 5.0 305, to make this work properly
Old Aug 26, 2009 | 09:41 PM
toomany's Avatar
Re: 2.73 Rear to 3.73 Rear
The gear in the tansmission will need to be changed to keep the speedometer accurate.
Old Aug 27, 2009 | 03:53 AM
so, would that be a ring and pinion gear like this ...
http://cgi.ebay.com/ebaymotors/GM-7-...Q5fAccessories
Old Aug 27, 2009 | 04:03 AM
Chezoom's Avatar
Car: 91 RS Vert, 87 SC T-Top
Engine: LO3, LG4
Transmission: 700r4's
Axle/Gears: 2.73, not sure yet
No. Tho's are the gears in the carrier its self. I think its a small plastic gear and it goes behind the tranny I believe.
Old Aug 27, 2009 | 04:19 AM
Do you have any idea what that part is called? If you are able to search for it on ebay copy and paste the link in a reply
Old Aug 27, 2009 | 04:29 AM
Chezoom's Avatar
Engine: LO3, LG4
not something you get on ebay, chevy dealership
use this thread, you might have to pm the OP
https://www.thirdgen.org/forums/tran...eedometer.html
Old Aug 27, 2009 | 07:24 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You'll need the ring and pinion, of course, and all that goes with replacing them, as well as the drive and driven gears to make the speedo read correctly. Phone these guys for what you need:
http://www.transmissioncenter.net/sp...n_______va.htm
The following FAQ may provide some info to consider:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Aug 27, 2009 | 02:44 PM
Will replacing the drive and driven gears to match the rear affect the way the car drives (or shifts)?
Old Aug 27, 2009 | 02:50 PM
JamesC's Avatar
No.
JamesC
Old Aug 27, 2009 | 03:25 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
PM me if you need any more help figuring it out.
hectre13
Dec 11, 2023 08:14 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Regal105
Aug 23, 2015 03:45 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
