9 bolt
Old Aug 26, 2009 | 07:28 PM
gtanut's Avatar
9 bolt
how much abuse will a 9 bolt take thanks
Old Aug 26, 2009 | 07:36 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: 9 bolt
They are stronger than the 10 bolt, but you can't get parts for them. Good luck with it. Some people have hit 11's. Depends on the car and traction.
Old Aug 26, 2009 | 07:40 PM
Stephen's Avatar
Car: 87 GTA
Re: 9 bolt
You can get all the parts you want. Just not as easily going to whatever store you want to. And you'll pay a little more $, for the 10 bolt "equivalent" part.
http://9bolt.com/ is one place & I believe Australia is STILL using the M78 center section!
Old Aug 26, 2009 | 07:45 PM
gtanut's Avatar
Re: 9 bolt
Thanks guys is 9 bolt.com only place that has parts
Old Aug 26, 2009 | 07:53 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: 9 bolt
I have a spare carrier that is worn if you need parts. I am trying to get out of 9 bolts. I also have a set of 3.45 gears.
Old Aug 26, 2009 | 09:23 PM
gtanut's Avatar
Re: 9 bolt
No thanks i was just wondering if it was worth putting new gears in or not
Old Aug 26, 2009 | 09:27 PM
Stephen's Avatar
Car: 87 GTA
Re: 9 bolt
I think they are, but not the cheapest to rebuild.
You could just get a complete LS1 rear end for a strong differential & bigger brakes.
Old Aug 27, 2009 | 03:20 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: 9 bolt
They can be if your posi is still good. If not, go with a 4th gen rear.
Old Aug 27, 2009 | 10:33 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: 9 bolt
Raytech is a lot cheaper for bearings/seals/shims.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
