T-5 FOR v-8 AND v-6 ..SAME?
Old Aug 27, 2009 | 09:42 AM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
Hi , i want to change from a 700r4 to a t-5..they are hard to find...can a 2-8 L v-6 T-5 BE USED ?..can i just change the bell housing?..besides the pedals ..what else needs to be modified from an auto car to a 5 speed?
thnks.
Old Aug 27, 2009 | 09:45 AM
nick86bird''s Avatar
Car: 1984 Trans Am
Engine: 383 4 bbl
Axle/Gears: eaton posi w/ 4.11's
Re: T-5 FOR v-8 AND v-6 ..SAME?
thnks.
https://www.thirdgen.org/forums/tran...ything-we.html
also check out the tech article on here on auto to manual swaps. fbodymotorsports.com also has a more in depth step-by-step guide for auto to T-5 swap
Old Aug 27, 2009 | 09:54 AM
82TA_JAIME's Avatar
Car: 92 Camaro RS
Engine: 305 L03
Axle/Gears: stock
Old Aug 27, 2009 | 11:11 AM
Ludo's Avatar
Car: T/A GTA & C4 Vette
You can use a V6 unit, but will need a different clutchplate (advance adapters) to compensate for the differences in input shafts.
But i think the gears of the v6 unit are to steep to use with a 3.23 rear axle.
As the T-5 is very rare here in Holland i am going to put a v6 unit in a c4 corvette, but it has a 2.59 rear axle
PurelyPMD
May 5, 2016 04:57 PM
Zane Story
Oct 8, 2015 12:40 PM
luvofjah
Sep 26, 2015 08:28 PM
DARKmj16
Sep 9, 2015 04:07 PM
Formula_88AE
Sep 3, 2015 01:47 PM
