9 inch rear
9 inch rear
If anybody is looking for a Ferd 9 in. rear i've found a almost perfect length to use. I'm getting a ferd 9 in. out of a '67 fullsize truck (F-100?). My rear measured a little under 55 inches from backing plate to backing plate. This rear in the truck measures 54 3/4 inches from plate to plate. I've got offset unilug wheels so it should work just fine. got a friend who is doing the welding/cutting and am getting a torque arm mount from currie. I'll let everybody know how it comes together!
Thanks,
Jason
Thanks,
Jason
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I'm installing one from a 1970 F-100. It was the perfect width and used the big bearings. All I needed was the housing. Everything else is changed. Center section, brakes, axles, mounts etc.
The only problem that I may see coming is the position of the pinion yoke. The 9" has the yoke more towards the passenger side than the third gen diff's is. I'm not sure how much of an offset there's going to be. The f-body diff is too far to the passenger side already so moving the 9" diff more towards center may even everything up.
A proper 9" housing will have a longer axle on the passenger side than the drivers to position the pinion closer to the center.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.586
Did either one of you guys get the rear to work? I know where I can get one of those to. What about the torque arm? Is the housing cast iron? It didn't look like it was. If not I can weld something on there to make it work probably. Thanks.
Brad...
1986 SC Camaro
Mods: Threw 2.8 in garbage, put in rebuilt
350 .060 over, XE268H Comp cam, Edlebrock
Performer Intake and Edlebrock 600 CFM Carb,
Pete Jackson noisy GearDrive (which sounded
cool for about 5 minutes, now I'm sick of it)
Rebuilt TH350, 3.42 Rear Gears. LCA RLB's.
B&M Mega Shifter.
Now has T5 in it. YES!!!
CenterForce Dual Friction Clutch.
Brad...
1986 SC Camaro
B&M Mega Shifter.
Car: 87 IROC L98
I'm going with ladder bars myself.
The housing is steel so if you want to fabricate some sort of mount for the torque arm, it can be welded onto the housing. You could buy the torque arm mount from Currie like gremlin is going to do and just weld it on and solve all the difficulties of fabricating your own.
The center section is cast iron if that's what you were mentioning. You don't attach the torque arm to the center section. It won't last very long.
Car: 87 IROC L98
Count the teeth on the ring and pinion. 41 on the ring and 10 on the pinion is 4.10 etc.
When you order a "new" 9" from places like Currie, Moser etc, you can custom order them with whatever you want. Axle spline count, posi, spool, locker, and any gear ratio available for the 9" which is a very wide selection.
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
<font face="Verdana, Arial" size="2">Originally posted by rocky383:
I'm going to get a new Ford 9". Can you get one with 3.42 gears and posi?</font>
colton_carlson
Mar 8, 2019 12:21 PM
