Which ones should i use??? so many options!!
Thanx
91 FireBird 305 V-8
Edelbrock Catback, Custom Alarm. Fourth Gen Console. i have six cupholders. all for starbucks!
Go|)Created The Earth, And Then Turned Up The Bass.
Here's My Audio Install!
"Honda's FOR ME TO POOP ON!" -Triumph...
Thanx
91 FireBird 305 V-8
"Honda's FOR ME TO POOP ON!" -Triumph...Supreme Member
Just get them out of a V6 or V8 thirdgen because I hear you got to cut the gas pedal off if you use one from a fourthgen.
89 T-Top GTA 350 5-speed (soon to be 6-speed)
(Jet hot coated)1 3/4 SLP headers,flowmaster force 2,no cat's,SLP cold air,MSD 6al,march pulleys,ported plenum,air foil,B&M ripper shifter,180 stat,alston SFC,spohn LCA relocation brackets,ES LCA and Panhard bushings,free mods.
0-60 5.2s
Track Time
60' 2.049
E.T. 14.14@96.7MPH (2270 FT)
13.76@99.4MPH corrected
0-60 5.2s
Track Time
60' 2.049
I used 4th gen ones. Cutting the gas pedal off is no big deal. Plus they line up better if you use the 4th gen master cyl.
Jimbuck, you are allover my posts!!!
Thanks,
anyways, what did it take, how did you cut? i have no idea, whats required, never delt with pedals...
thanx again!
91 FireBird 305 V-8
Thanks,
thanx again!
91 FireBird 305 V-8
Dremel with a cutoff wheel cut thru it like butter when I did mine.
There's a fitment issue with thirdgen clutch pedal and fourthgen master cyl rod. It can be overcome with some grinding, but is much easier to bypass by using 4th gen pedals.
1982 Z-28
See http://www.mycar.net/mafb/registry/detail.cfm?id=276 for details
1982 Z-28
cut it off.... then... Throw at some one?
lol, no idea, ,then what, how do i install new one?
91 FireBird 305 V-8
91 FireBird 305 V-8
