Rebuilding my T5 World Class, Questions inside....
Do I need any special tools to do this job? It looks like something I can knock out myself. If I can do an engine, then I guess I can handle this......
Any other comments would be appreciated!
Thanks....
Black 1983 Trans Am
350 Cross-Fire Injection
T5 World Class
3.42 Locker
7747 ECM
Flowtech Headers
!Cat
Factory 98 WS6 muffler (oval tip)
Thanks....
Black 1983 Trans Am
T5 World Class
3.42 Locker
7747 ECM
Flowtech Headers
!Cat
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i rebuilt my non world class T5 last year, it wasnt hard at all, just be careful when you take the top cover off that you dont get the forks messed up, i only had to go to a transmission shop because you need to pull the rear gear off the top shaft to get the rear bearing out that was it, i didnt have any snap ring pliers, but i recommend you get a pair.
86 Camaro with 88 305 LB9 using 86 carb setup, edelbrock performer manifold, 305 S/R Torquer Heads, Hedman Headers, Crane Compucam 2032 edelbrock cat-back, gutted cat, slp underdrive pulley, mallory ignition, 305 h.o dual snorkel air cleaner, hypertech thermomaster chip,160 degree thermostat, 5-speed, 3.23 posi
95 Beretta Z26, 3100 V6, 4 Speed auto, stock
I think these guys sell a video.
http://www.hanlonmotorsports.com/HanlonTIC.html
Car: '89 Formula
Engine: 355 TPI
Axle/Gears: 3.70 9 bolt.
A friend's hydraulic press, a bearing separator plate, and some homemade type things like a foot of 2.5" exhaust pipe helped me out greatly.
'89 Formula - Thunderchicken - 355 Vette L98/T-56/3.70 9-bolt/black/t-tops - the fun car!
'90 GTA - The GTA - 5.0 LB9/TH700/3.27 9-bolt/black/t-tops/tan leather - the cruiser.
WhteRbt
Sep 21, 2015 09:48 AM
