700R4 in an older car
Old Dec 8, 2001 | 11:06 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
how hard would it be to put a 700R4 in an older muscle car say a 1970 Chevelle
Old Dec 8, 2001 | 11:27 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Fairly easy, the tranny will bolt in and onto your crossmember if you elongate the bolt holes. The frame will have to have 1 bolt hole on each side drilled out and the other elongated. The hardest part would be to get a driveshaft fitted in but if you were to measure things out im sure you could get a Fbodys drive shaft and extend or shorten it to fit. The hardest part is deciding if you want a locking converter. If you wanted the converter to lock you would have to buy the harness kit for it. If not you could get a non locking converter and have the part throttle downshift eliminator installed to help out on the highway.
SSC
Old Dec 9, 2001 | 09:14 PM
how much is it to have a driveshaft shortened or lengthened?
BlueIroc-Z
Jun 9, 2019 03:22 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
TreDeClaw
Aug 14, 2015 06:58 PM
