700r4 linkage problem?
Old Sep 3, 2009 | 09:43 PM
NJrFirebird's Avatar
Car: 1989 Firebird
Transmission: 700r4 w/ kit
i swapped out 700r4's and i ran into a snag. the problem is when i connected the cable and linkage, the cable will not push gear shifting tab on tranny back. i know the way im wording it may be confusing.... the tranny is dry as in no transmission fluid in it yet. that may be the problem but im not sure. ill try to rephrase it again. with the key turned, brake down , and shift into drive the tranny linkage does what its suposed to do but then when you go back into park the cable does not push foward to disengage tranny. hope that was better.
Old Sep 3, 2009 | 11:49 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 700r4 linkage problem?
Have you tried a new shifter cable? Is the mount on the tranny for the cable identical to the old (ie not bent or anything)?
Old Sep 4, 2009 | 07:12 AM
Pocket's Avatar
Car: 91 Trans Am
Cable isnt adjusted right
Slide the cable to tranny arm as far back as you can and slide the bracket as far forward as possible
If it still wont reach youll have to elongate the bracket holes
Old Sep 4, 2009 | 10:11 AM
Car: 1989 Firebird
everything is exactly identical, same 700r4 as the old one. its almost like then you go from drive to park the cable doesnt have enough force to push the shifting arm back or like the cable is going somewhere else besides pushing out. what do you mean elongate the holes?
Old Sep 4, 2009 | 04:57 PM
Grinch Racing's Avatar
Car: 91 B4C 92 Z 93LT1
Engine: L98s & LT1s
Transmission: 700R4s all around
Axle/Gears: 3.23x2 & 3.73
I would almost bet the cable was broke during the swap... i,ve done it way too many times.. I know better but its in the way coming down. i try to use the traction arm to pin the cable out of the way and still end up breakin the cable.
Old Sep 4, 2009 | 10:34 PM
Car: 1989 Firebird
i was told that sice it was a dry tranny (no fluid) that that may be the problem. the trans goes from park to drive fine but going to drive to park the cable doesnt move.
Old Sep 5, 2009 | 12:12 AM
Pocket's Avatar
Car: 91 Trans Am
If you can move the shifer arm by hand you should be able to do so by cable as well
Wet or dry makes no difference
Elongate means turn the circle hole and make it an oval to slightly adjust the bracket in a direction
camaro11j
Sep 19, 2018 08:49 AM
someone972
Aug 30, 2015 12:52 AM
g.l.mos
Aug 22, 2015 12:02 AM
spaigo
Aug 21, 2015 07:46 PM
TreDeClaw
Aug 14, 2015 06:58 PM
