Anyone have the aftermarket T-56?
Old Dec 9, 2001 | 12:06 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
I am going to buy an aftermarket T-56 but need to know your experiences. Does the shifter come through the stock hole? Any other problems? Transmission tunnel clearance probs? Thanks
1991 Firebird
350 L98 (was a 305 TBI),T-5,Edelbrock TES and cat back,Accel manifold
NOS,subframes,jegster torque arm,MSD Digital 6
AFPR,Lakewood lcas
Hurst linelock,SLP cam (206 212 .480 .486),relocated battery,cold air,Hypertech chip,centerforce df,clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
autopower rollbar
12.33 @ 114.83 juiced uncorrected
13.510 @ 102 non juiced uncorrected
Old Dec 10, 2001 | 11:08 PM
Car: 1991 Firebird
Engine: 427 LSX
Really? I will be the first?
Old Dec 11, 2001 | 01:58 PM
BigRuss's Avatar
Check this site out:
http://www.sallee-chevrolet.com/BorgWarner/bwt56.html
Also, South East Thirdgen's tech article on the T56 swap says you'll have to cut out a hole in the transmission tunnel for the shifter on a regular T56, but I've never heard of anybody having to do that, so I wonder if he was talking about the aftermarket T56. Can someone verify this?
See:
http://www.sethirdgen.org/trd.htm
91 Camaro RS - Engine: 350 bored 60 over, Edelbrock 600 and Performer RPM intake, mild cam upgrade, flat pistons, 3 angle valve job, moly rings and pushrods, HV Melling oil pump, double-roller timing chain, stiffer valve springs, Hedman 1-5/8 headers, Flowmasters, K&N filter, 100 amp alternator Suspension: KYB adjustable gas shocks and struts, Eibach coil springs, poly trans mount and end-link kit, Falken tires.
Old Dec 11, 2001 | 02:40 PM
SteveSpohn's Avatar
The shifter on the aftermarket T-56 lines right up with the T-5 hole. It fits in the tunnel just fine.
Steve
Spohn Performance: F-Body Chassis/Suspension Specialists
Old Dec 12, 2001 | 07:28 AM
BigRuss's Avatar
Okay, so what about a regular T56? Does it fit the shifter hole fine without modification? Like I said, I've only seen that in the SE Thirdgen tech article, and no one else has said anything about it.
Old Dec 12, 2001 | 08:40 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
No, you have to extend the T5 hole back about an inch for the production T56... at least, I had to.
"Beware he who would deny you access to information, for in his heart, he dreams himself your master"
'84 Black Camaro Sport Coupe ZZ4 350 M6 -- '84 Olds Cutlass Supreme 231 A3
'91 Medium Blue Metallic Z28 400 A4 -- '99 Navy Blue Metallic Firehawk #120 346 M6
Old Dec 12, 2001 | 08:42 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Is it true that you can use the aftermarket T56 with a lakewood scattershield #15015 and mechanical linkage clutch?I can swear I read this somewhere but cant seem to find it anymore.I am interested because I happen to have both of these in my car and this would really simplify my swap from the 4 speed to 6.Any help appreciated!!
1982 Z28:355,4 Speed,Lots of bolt ons
Old Dec 12, 2001 | 08:51 AM
BigRuss's Avatar
Yes, according to the Sallee Chevy website posted above, you can use that scattershield and linkage.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
