Problems after installing new shift cable
Old Sep 5, 2009 | 05:12 PM
StevenB L98/LS1's Avatar
Car: 1989 Firebird Formula
Engine: 5.7 LS1
I installed a new shift cable because the original one was shot. I got everything hooked up correctly but now the alignment of all the gears are all wrong. I go into reverse its in between park and reverse, when its between reverse and neutral its in neutral, when its in neutral its in drive. When i put it in neutral, im actually in drive. when i go to the regular d drive gear, im in the 2nd d drive actually.
Mainly my problem is park. I drove it for 2 weeks with it out of alignment because it still worked, but you would have to always force it into park for it to be in park.
Today i tryed adjusting it, and i didnt get any improvement. I moved the piece as far forward as it will go and re connected the shift cable to it, and all seemed good when i cranked it up and put it into reverse all gears seemed to be in alignment again. But then i lost park.
Its everytime i shift into any other gear it will be firm like it should. Its soft everytime i go to put it in park and i have to hear it make this click noise to know its in park barely.
Any ideas what could be wrong? or if i did anything wrong?
Old Sep 6, 2009 | 02:51 PM
Grinch Racing's Avatar
Car: 91 B4C 92 Z 93LT1
Engine: L98s & LT1s
Transmission: 700R4s all around
Axle/Gears: 3.23x2 & 3.73
Re: Problems after installing new shift cable
You need to bring you adjustment back just a tad..
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
dhonda200
Aug 11, 2015 11:50 PM
