Got my T5 today
Old Sep 6, 2009 | 09:30 PM
89Firebin's Avatar
Car: 89 Firebird Formula 350
Engine: 1974 350
Transmission: '84 Trans Am T5
Axle/Gears: Borg warner 3.27
Got my T5 today
Scroll.....
Last edited by 89Firebin; Nov 12, 2009 at 04:56 PM. Reason: Way too much stuff that didnt matter should of just got to the point.
Old Sep 6, 2009 | 09:31 PM
89Firebin's Avatar
Engine: 1974 350
Re: Got my T5 today
A little more
Old Sep 6, 2009 | 09:34 PM
89Firebin's Avatar
Engine: 1974 350
Re: Got my T5 today
Hi,
I bought a t5 for my 89 Firebird a while back and I have a few questions about the speedometer drive.
Here is a pic of the speedometer drive for the 700r4 that was in it.
and speedometer drive gear (700r4)
The speedo drive in the attached pic in my next post is from another T5 transmission I bought for parts.
Are both of these the same Pulse per mile? Does my car have 2000 or 4000 (I think those are the numbers)? Will the one below work in my car? I think I will have to do some speedometer gear changing, correct?
Thanks,
Ryan
Old Nov 12, 2009 | 05:08 PM
89Firebin's Avatar
Engine: 1974 350
T5 speedometer drive pic
Pic.
Old Nov 12, 2009 | 09:32 PM
PV9685's Avatar
Engine: 305 Vortec, Single-plane, 4 barrel
Transmission: T5, soon 700R4
Axle/Gears: 88 10 Bolt, Disc, Auburn, 3.23
Re: T5 speedometer drive pic
Well, I just typed a post and accidentally hit the back button.. oh well. I'll sum it up - I had to replace the yellow module that goesconverts the VSS signal for the speedo in my 89 Firebird Formula 305/T5. It ended up that some other car models have different convertors (I think I recall them being called a DRAC?). Anyhow, I believe I found that ours are all the same (not dependent on gearing) - the drive/driven gears compensate.
Anyhow I did some simple math on a calculator to figure out your question of 2000 or 4000 pulses per mile. I got 3888 but that's a bit off - I had the Red 9t drive gear and was going to use a 23t driven for my 3.23s so i wouldn;t have to pull the tail off an already dying gearbox. I know the 9t:23t is a little off but my math is probably pretty good.. So I'd say it probably is 4000 not 2000.
Last edited by PV9685; Nov 12, 2009 at 09:34 PM. Reason: My math was off :D did Pi*r when I shouldve done Pi*d
Old Nov 14, 2009 | 07:20 PM
89Firebin's Avatar
Engine: 1974 350
The auto transmission has 17 tooth drive gear, 45 tooth driven, 3.27 rear end gears, and 245/50R16 tires if that helps any.
Thanks for the help,
Ryan
Old Nov 14, 2009 | 08:00 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
it is 4000ppm
Linson
Oct 24, 2025 02:00 PM
86IROC112
Nov 7, 2015 06:50 AM
bjpotter
Oct 4, 2015 07:48 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
paul_huryk
Oct 1, 2015 04:27 PM
