type of shifter for new tremec t56 ??????
Old Dec 12, 2001 | 11:52 PM
dsavio's Avatar
the new tranny did not come with a shifter handle .this is the aftermarket tranny that bolts to a t5 bellhousing.im not sure if i should get just the handle or the complete shifter like a ripper shifter. any help as always is appreciated
Old Dec 13, 2001 | 11:08 AM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
Dude, i just bought the same trans. Just buy a pro 5.0.
1991 Firebird
350 L98 (was a 305 TBI),T-5,Edelbrock TES and cat back,Accel manifold
NOS,subframes,jegster torque arm,MSD Digital 6
AFPR,Lakewood lcas
Hurst linelock,SLP cam (206 212 .480 .486),relocated battery,cold air,Hypertech chip,centerforce df,clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
autopower rollbar
12.33 @ 114.83 juiced uncorrected
13.510 @ 102 non juiced uncorrected
Old Dec 13, 2001 | 02:04 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
So this new t56 trans bolts right up to a t5 bell with no adapter plate or anything?can you use a mechanical clutch linkage set up?Where did you get them and how much?This would make my swap so easy,thanks for any help!
1982 Z28:355,4 Speed,Lots of bolt ons
Old Dec 13, 2001 | 02:09 PM
mrls199's Avatar
from what i remember about this trans, it uses the T5 shifter (not the T56 shifter). Also, http://www.sallee-chevrolet.com has them for $2295 + $40 to redrill for straight up bellhousing
Old Dec 13, 2001 | 02:11 PM
dsavio's Avatar
gofaster,
thanks ill buy that stick and shifter did it fit right in? or did you have to bend the shift arm?
one bad, darkhorse performance $1899 spohn torque arm and center brace 400 im not sure if the mechanical linkage works? go to salle chevy site it will tell you
Old Dec 14, 2001 | 12:51 PM
Car: 1991 Firebird
Engine: 427 LSX
I don't have my trans yet. it is in the mail now
1991 Firebird
350 L98 (was a 305 TBI),aftermarket T-56 (in the mail) ,Edelbrock TES and cat back,Accel manifold
AFPR,Lakewood lcas
AFR 190s
autopower rollbar
Old Dec 14, 2001 | 12:55 PM
Car: 1991 Firebird
Engine: 427 LSX
Does anyone know which part number to get??
Old Dec 18, 2001 | 03:57 PM
Car: 1991 Firebird
Engine: 427 LSX
ok, i ordered a pro 5.0. just tell them it is for an aftermarket t-56 and you need the t-5 lever. It is supposed to fit directly in my car with no probs. I will let you know on the 26.
Old May 20, 2002 | 08:36 PM
'91 Formula's Avatar
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Transmission: 6-Speed
Axle/Gears: Stock 10 bolt 3.42
GofasterFirebird...how is the Pro 5.0?
Old May 20, 2002 | 08:49 PM
388iroc's Avatar
i have...
i have the pro 5.0 with the aftermarket t56. i didnt specify the t5 handle and it fits fine except for the reverse, you have to push a little to nudge the console over like an eighth of an inch or so. i had a ripper shifter with the t5 which i liked better but the pro 50 is wearing in and im liking it more. if you dont hook up the reverse solinoid the its a pain to get it into reverse but you can do it and after awhile it gets a lot easier. hope it helps.
Old May 21, 2002 | 04:58 PM
NTChrist's Avatar
GoFaster: Did you finally blow up your T-5?
Night rider327
Feb 25, 2016 09:50 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
ndndndnd
Sep 28, 2015 08:00 AM
