NV3500
Old Dec 14, 2001 | 01:34 PM
pontiac's Avatar
NV3500
"NV3500: This transmission is normally found up against the stock 4.3 V6 and does not require an adapter when converting to
the V8."
would this s-10 5-speed transmission fit to our 3rd gens?
-P
Pontiac Trans Am GTA'89
CC1 GW6 G80 JG1 L98 MXO N64 WS6 822
mods: firebird '89 four spoke steering wheel and i'm still not running low 13's yet!
Old Dec 14, 2001 | 02:03 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
I have the NV3500 in my 92 GMC 5.7 liter (came that way new). It held up to my Paxton supercharged 5.7L and I tore out 2 8.5 inch rearends at the track with it. Still doesn't grind or make unusual noises. But it does look awfully long under the truck. I don't think it will just drop in and bolt up. I could be wrong though.
Old Dec 28, 2001 | 04:48 PM
pontiac's Avatar
anyone have opinions how feasible this would be? i think it's at least as common, plenty available. low rev engines would be just fine with 5-speed gearbox? and tough one as previous writer said
-P
Old Feb 26, 2009 | 03:39 PM
Poppa Chubby's Avatar
Car: Vert IROC Camaro
Engine: 355ci
Axle/Gears: 9-bolt w/3.45s
Re: NV3500
Has anyone ever performed this swap?
Maybe with one of the LSx engines as a direct bolt-in 5-speed?
I know GM put these trannies behind the 4.8L engines in small pick ups.
Old Mar 1, 2009 | 07:06 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: NV3500
I put one in a 69 c-10 and it works so dont give up hope
unless you have not heard that these trannies are weak
brharris27370 has the best 3500 that I have ever heard of
put a wc t5 and sell the 3500
unless you prefer the hard way
I am the same way
Old Mar 3, 2009 | 04:10 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: NV3500
The NV3550HD was offered in fullsize half-tons. I'm not convinced it's any stronger than any other NV3500. The GM versions were offered with at least 2 different gear sets. The better one is nearly identical in ratios to the T5 in my '85 2.8 Camaro.
1) 3.50:1
2) 2.14:1
3) 1.39:1
4) 1.00:1
5) 0.73:1 (my T5 was 0.78:1)
This would be great with a 2.73:1 - 3.08:1 axle, depending on your engine. Beware of the version with the 4:1 first gear.
garnerm
Jul 12, 2015 03:36 PM
garnerm
21
May 10, 2015 11:32 AM
mud runner
May 9, 2015 09:28 PM
R3500
Sep 9, 2009 03:45 PM
1low67
Jun 3, 2005 10:17 PM
