7730 ECU, VSS, Drac...
Old Jul 11, 2015 | 09:20 PM
garnerm's Avatar
OK so I am using a NV3500 Trans on my TPI build. Issue, NV3500 is a 40 PPM VSS, 7730 ECU needs a 4000 PPM. The 90s DRACs out of suburbans turn 40PPM into 4000PPM. Im just not sure how to wire it.
So the Blue wire gives the pulse I need. The wiring for the 7730 ECU is wire B10 and B9 go to the VSS. So I know the green,purple from the drac go to the VSS, Black/brown go to the Ground and Key 12+, connector 2 is for CC so i dont need it, White wire is ABS so not used and other brown wire is 2000pulse So i dont need it and Blue is the 4000 I need so it will go to the ecu but where do I pin it in at? I know I cant just slit to both wire I assume one wire from the ECU powers the VSS and the other recives the signal but I dont really know how the VSS works.
Old Jul 12, 2015 | 09:14 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 7730 ECU, VSS, Drac...
Need to use the 'To ECM pin A10 (Brown)' wire and run it to pin C6 on the '7730 ECM.
Then zero this flag/bit in the BIN: Mag VSS, that will tell the ECM firmware to use the 2K PPM optical input instead of the 4K PPM sine wave (magnetic) input. More info on this flag:
It is location $18, bit 6 of option word 3.
RBob.
Old Jul 12, 2015 | 03:15 PM
garnerm's Avatar
How do you know unused pins do anyways? what else am I missing out on with the unused pins on these ECM?
Old Jul 12, 2015 | 03:36 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Been in this stuff for a long time...
Can control a second fan on F8, use an oil temperature sensor on F12, an external knock filter on B8, may be some I missed, but they are used in $8D.
There is a note upon using the optical VSS input. The pulses streams that the ECM creates and outputs will not be available. They are only available when using the magnetic VSS input.
I didn't mention it earlier as your application doesn't look like it will need it. But others reading this may be using a different vehicle.
RBob.
$750 L98
Feb 1, 2025 02:25 PM
GTAman
Jul 3, 2024 07:29 PM
InfernalVortex
Apr 20, 2021 11:31 AM
KO1
16
Oct 15, 2015 05:00 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
