1990 rs rearend
Old Sep 13, 2009 | 04:41 PM
hollis3206's Avatar
Car: 1990 camaro rs
Engine: 350 w/holley carb
Transmission: 5 speed
Axle/Gears: stock
1990 rs rearend
I have a 90 camaro rs,It came with the 305 5 speed setup.I have replaced the engine with a goodwrench 350 86 and earlier style crate motor.I plan on beefing the motor up to around 400hp.I want to know what kind of limited slip rearend setup i should get to handle the increased power and not be to pricey.
Old Sep 13, 2009 | 04:47 PM
big gear head's Avatar
Re: 1990 rs rearend
Not much available for the 3rd gen that isn't pricy. The 7.5 10 bolt isn't very strong and there isn't anything else from the factory that's much better. You can add a few parts to what you have to make it a little stronger, but it is still very limited. An Eaton Posi and a T/A Performance aluminum cover will help some. You should already have the 28 spline axles. A new Moser 12 bolt starts at about $2200 plus shipping with an Eaton Posi and 30 spline C clip axles.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
HoosierinWA
Oct 7, 2015 10:15 AM
bjpotter
Oct 2, 2015 09:12 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
