Transmission lockup question 700r4
Old Sep 20, 2009 | 10:25 PM
GMODUDE's Avatar
Car: 92 Camaro RS
Engine: 5.7L 385 Fastburn
Axle/Gears: 9 Bolt 3.70 Gears
I got a 385 fast burn crate motor recently with a built 700r4. Becuase i am going carb on the engine my lockup on my tranny wont work, right? I read on the tech articles that you can make up your own lockup but it goes through your aldl plug. Dont you need your computer to use that? and if I keep the computer in the car, but obviously most of the sensors wont be plugged in, would the lockup switch work?Ide like to have lockup but without the computer fully engaged will the switch still work?
Old Sep 21, 2009 | 11:59 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Transmission lockup question 700r4
The best solution for you would be either this: http://www.summitracing.com/parts/BMM-70244/ if you have a cable type speedometer, or this: http://www.summitracing.com/parts/BMM-70248/ if yours is non-cable, or this: http://www.summitracing.com/parts/PRF-60109/ which isn't adjustable, but it doesn't care which type of speedometer you have.
Old Sep 22, 2009 | 12:13 PM
GILLIGAN's Avatar
Car: 1992 RS
Engine: BLACK&DECKER AQUARIUM PUMP
What I did is remove my pan and wired the tcc solenoid ground to the pressure switch bypassing the temp switch so when the trans is in o.d. and pressure is reached the switch grounds activating the solenoid. I also need to connect a 12 source to the A terminal of the 4 pin trans connector which I ran through my brake switch and a toggle switch for control of the circuit. I have not run my car yet but this should work.
Old Sep 22, 2009 | 09:57 PM
GMODUDE's Avatar
Car: 92 Camaro RS
that kit looks like i could easily use my own equipment for it. r u sure the tech article switch wont work on my car?
Old Sep 24, 2009 | 09:51 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
you could also just wire it to lock up in 4th gear OR when you turn the switch on manually.
a 700r4 will lock up in any gear but 1st (for obvious reasons) so if you manually tell it to lock up it will do it in any gear at less than 50% throttle (i believe)
Old Nov 11, 2009 | 09:18 PM
mavcar38's Avatar
Car: 89 Iroc
Engine: 350 Carb
Transmission: 700R
Or you could just put a non-lockup converter on it. Thats what I did. You will just lose a couple hundred rpms in OD.
Cleotiz
Jan 6, 2018 08:56 PM
Reddeath210
Oct 6, 2015 08:20 AM
formula_novice
Aug 18, 2015 08:48 PM
redmaroz
Aug 16, 2015 11:40 PM
