87 10 bolt drum to an 89 9 bolt disc...
Car: 1987 IROC Z/28 Camaro
Engine: 355
Axle/Gears: 9 Bolt w/ 4.10s
I'm just trying to be clear on everything I need here.
From what I understand, I'm good to go except for the master cylinder? I just need a 4 wheel disc master cylinder correct?
Will my old e-brake cable work, or will I need a 9 bolt e-brake cable? What's the difference?
Anything else I'm forgetting? Thanks!
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 87 10 bolt drum to an 89 9 bolt disc...
https://www.thirdgen.org/forums/susp...fferences.html
For best brake performance, however, you'll need to swap the proportioning valve. And, of course, you may need to change the drive and/or driven gears to make the speedo read correctly.
JamesC
Engine: 355
Ah... I see! Does the prop valve need to come from a Chevy dealer?
Any idea about the ebrake cable?
Thanks again.
Thanks again.
http://www.flynbye.com/
Drum cables won't fit. I assume on an 89, you'll have 11.7" rotors and PBR calipers. This latter is the set-up (J65) you should buy for.
JamesC
Changes required for the 9-bolt swap...
1) Proportioning valve for the 9-bolt (master cylinder dose not require changing).
2) The parking brake cables for the 9-Bolt (old 10-bolt cables will NOT work).
3) Flaring tool for brake lines ( may be different). Was for me.
Did this swap nine years ago.
dbrochard
Oct 3, 2015 12:43 PM
rudolphschenker
Sep 4, 2015 02:41 AM
