700r4 overdrive problems need help
Old Sep 25, 2009 | 05:03 PM
89iroczz28's Avatar
i have a 89 iroc z tbi 305 with 700r4 iam needing info on why my overdrive stoped working...does the tv cable need to be reset or what it doesnt slip but it does shift hard into second like it has a shift kit in it its been like this since i bought it few months ago ive replaced the tranny fluid with lucus fluid and replace the filter but no changes it does shift smoother
its second one ive bought other one is 88 iroc tpi
you may email me at armypfcsneed@aim.com if you like
Old Sep 25, 2009 | 06:41 PM
firebird1992's Avatar
Car: 1992 firebird
Engine: V6
Axle/Gears: 10 open 3.42
Re: 700r4 overdrive problems need help
man i have the same problem ever sense i got my transmission rebuilt but i still get the same gas mileage somewhat between 12-23 mpg at like 55 mph i at almost 2200 rpm
Old Sep 25, 2009 | 06:48 PM
89iroczz28's Avatar
yeah same here i cruze mostly around 60 at 2500 rpm that extra gear is handy when driving a long distance iam going to go by a local transmission shop and ask then and ill post what they tell me they have 3 year 75000 mile warrenty on there stuff they do seem to be good place there always busy
Old Sep 25, 2009 | 11:14 PM
Car: 1992 firebird
Engine: V6
a other thing did u check your fluid level
AAMOCO where i had my trans rebuild overfilled my trans up to the little bent piece. but i had that taken care of 2 days after it was done and check on a 2nd trans cooler it helps keep them temp low
Old Sep 26, 2009 | 01:15 AM
johnnyzombie's Avatar
Car: 1991 z28 camaro
adjust the detent cable and see if that helps if the valve body isnt working properly then it feels like the tranny is going out
Old Sep 26, 2009 | 02:15 PM
Car: 1992 firebird
Engine: V6
where is that at on the trans?
Old Sep 26, 2009 | 06:42 PM
the adjustment it on the throttle body there should be two cables going to your throttle body one is the detent and one is the cruise control. have someone hit the gas pedal so your are at wide open throttle there should be a clip on one of the cables you release the clip and while the gas pedal is still depressed you pull the cable snug leave a very small amount of slack now release the pedal and make sure the blades close all the way in the throttle body now go for a drive is shoule shift very precise after that is not then take some slack out should be no more than 1/8 of an inch of slack
Old Sep 26, 2009 | 06:51 PM
Car: 1992 firebird
Engine: V6
yep that did the trick
Old Sep 26, 2009 | 08:28 PM
glad thats all it was
Old Sep 27, 2009 | 02:42 PM
89iroczz28's Avatar
well lets go out side since it isnt raining here bristol tn and adjust the cable hopefully itll work
Old Sep 27, 2009 | 07:50 PM
Car: 1992 firebird
Engine: V6
yea man the shifts are soooo smooth now 55 at 1700-1500 rpm and i can hit 125 now lololol it's crazy what a simple cable can do
Old Sep 27, 2009 | 09:59 PM
glad it helped
Prodigious
Nov 7, 2020 09:23 AM
camaro11j
Sep 19, 2018 08:49 AM
Prodigious
Oct 4, 2015 11:20 PM
someone972
Aug 30, 2015 12:52 AM
g.l.mos
Aug 22, 2015 12:02 AM
