What size torque converter?
Old Sep 28, 2009 | 09:04 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
i am taking my car into the shop to fix it because i am at my wits end as to what is wrong with it and whileit isthere i am also repacing my stock torque converter. the car is a 1984 Pontiac Trans Am with a fresh 350 that i had put in hooked to a 700R4. i was looking at a 2400 stall torque converter to match up to my engine and was looking for imput as to what size to get. the engine puts out 320hp at the crank, 249 to the wheels. cam is a .515 intake, .530 exh. any imput would be greatly appreciated.
Old Sep 29, 2009 | 11:31 AM
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
Re: What size torque converter?
Your only option is a 12" stock style core. Look for something with internal brazing and roller bearings for strenth and less friction. You couldn't use a 10 inch and get the stall that low. If you want more details you can PM me. I have some ready to ship as well.
Old Sep 29, 2009 | 02:34 PM
Ozz1967's Avatar
Car: 1984 Trans Am
PM sent.
Old Sep 29, 2009 | 03:17 PM
Ozz1967's Avatar
Car: 1984 Trans Am
So what would be a good streetable converter then? I'd like to stay under 2800ish if possible. My powerband is 1800-6k which is why I was thinking 2400 would be a good stall speed.
Old Oct 1, 2009 | 10:36 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
A 12" 2400 stall is a great match for a powerband like that. I have been there, done that, and I tried both a 12" 2400 and a 10" 3000, the 12" 2400 was far better to live with.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
toronto formula
Nov 10, 2015 06:17 AM
xxx3man`
Sep 23, 2015 10:37 PM
gwade12
Aug 8, 2015 08:17 AM
