which spedo gear do I use
Old Oct 1, 2009 | 08:33 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
the trans is out of a 89 formy
the original rear was a 2.73 10 bolt
now I am putting in a 3.27 9 bolt
which speedo gear do I use
I have already read all the posts and they confuse me
I just want a part number please
thank you
Old Oct 1, 2009 | 10:07 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: which spedo gear do I use
If you'd like me to figure it for you, I'll need to know your rear tire size.
Old Oct 1, 2009 | 10:18 AM
jamon8's Avatar
Engine: 350 tpi
245 60 16
thank you
Old Oct 1, 2009 | 10:27 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
that must be a typo, there's no such size. If you meant 245/50R16, then you can use a 38 tooth driven if you have a 15 tooth drive, or a 43 tooth driven if you have a 17 tooth drive. If you have an 18 or 19 tooth drive, you'll need to change it.
Old Oct 1, 2009 | 11:12 AM
jamon8's Avatar
Engine: 350 tpi
your right they are 50s
thanks for the info
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
