cones bottoming out in 9 bolt
Old Sep 26, 2009 | 10:13 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
what should I do
buy new cones
machine old cones and shim
get a new carrier- too expensive
Attached Thumbnails cones bottoming out in 9 bolt-dscf0941.jpg   cones bottoming out in 9 bolt-dscf0943.jpg
Old Sep 26, 2009 | 11:53 AM
big gear head's Avatar
Re: cones bottoming out in 9 bolt
The method that I have heard is to machine the end of the cone and put shims under the axle gears. I haven't done one myself, but I'm sure that the day will come when I do.
Old Sep 27, 2009 | 08:57 AM
jamon8's Avatar
Engine: 350 tpi
would it hurt anything if I left the carrier alone and delt with the one wheel peel
Old Sep 27, 2009 | 10:59 AM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
It won't hurt to just leave it. I've had luck filing a few thousands (.005 or so) off the ends and shimming them. It usually brings them back to life for a while. But if the inside of the cone is hitting (as opposed to the outside edge), they will need to be milled.
Old Sep 27, 2009 | 01:14 PM
jamon8's Avatar
Engine: 350 tpi
so if I go with the milling and shimming how much should be taken off and how big of a shim should I use
Old Sep 27, 2009 | 03:15 PM
As the cones wear the axle gears move farther apart. This makes the gears contact farther out toward the face of the tooth instead of in the center where they are suppose to contact. This makes the gears weaker. The gears need to be shimmed so that they make contact in the correct place so that they will not break. The Borg Warner unit is stronger because it has 4 pinion gears instead of 2, like most rear ends.
Old Sep 28, 2009 | 12:09 PM
jv9999's Avatar
Engine: 5.7L/350
This link will help: https://www.thirdgen.org/forums/faq-...now-about.html
Old Sep 29, 2009 | 08:00 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
As biggearhead said it will hurt it if you leave it that way. There will be too much clearance on the spider gears and if you beat on it a for a bit it will break. The best bet is to machine the ends down and shim it tight again. I had to do that with a "supposedly" tight rear end. Its not that hard and i have a very tight posi again. Also, when you go to put new oil in, do not use a limited slip additive. Cone type LSDs do not need it and it will actually prematurely wear it out since the cones will be allowed to slip too much.
Old Oct 1, 2009 | 02:52 PM
jamon8's Avatar
Engine: 350 tpi
ttt
Old Oct 1, 2009 | 03:28 PM
subroc's Avatar
Engine: 355 TPI
Here is the pdf with everything you should need to know about setting up your 9 bolt. Also read the link above that has already been posted (the everything i know about 9 bolts link). After these two items you should be good to go.
http://www.geocities.com/luckyducky....air30Nov04.pdf
Old Oct 1, 2009 | 04:40 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
That link doesnt work?
Old Oct 1, 2009 | 04:50 PM
subroc's Avatar
Engine: 355 TPI
Sorry. Heres the link i was trying to post. Ill edit the one above too. Its the HTML version of it. Click the link and then click the top link once your in. That way you can see the pictures as well. Otherwise its just text.
http://74.125.113.132/search?q=cache...ient=firefox-a
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
billybob6110
Sep 23, 2015 01:30 PM
Jlanz55
Sep 6, 2015 07:28 PM
Formula_88AE
Sep 3, 2015 01:47 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
