Long Shaft/Short Shaft Question
Old Oct 7, 2009 | 03:50 PM
gunner1204's Avatar
Car: 1987 Camaro Z28
Engine: 355c.i. Carb.
Transmission: TH350
Can the tail of the long shaft TH350 be swapped onto the TH350 short shaft transmission and vice versa, I would like to use my short shaft transmission without modifying the driveshaft. If not its no big deal but if it would work that would be great any advice is greatly appreciated.
Old Oct 7, 2009 | 06:57 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Long Shaft/Short Shaft Question
You would also need to replace the output shaft. When assembling a transmission, the output shaft goes in first since it's at the back of the transmission. You can't just swap the tailshaft housings.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Aug 22, 2015 06:52 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
MENINBLK
Aug 5, 2015 11:58 PM
