t56 reverse lockout
Old Oct 11, 2009 | 12:18 AM
Almo the Pirate's Avatar
Car: 1989 iroc-z
Engine: mildly built TPI 350
Transmission: 97 T56
Axle/Gears: 3.73 posi
t56 reverse lockout
i got the pigtail for the reverse lockout, but i dont know how to actually hook it up.
it was a factory auto car.
what wires go to the reverse lockout and how do they hook up?
i also dont have the reverse lights hooked up yet because i need the connector, but im not sure how ill hook those up either.
Old Oct 11, 2009 | 11:22 AM
matthufham's Avatar
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Re: t56 reverse lockout
reverse lockout, 1 goes to ground, 1 goes to the brake switch orange wire or yellow, so when you hit the brake it releases reverse. you're not going to go 4 to 5 while on the brake are you? if it works backwards, switch the wires
reverse lights, connect 1 to the blue wire in the console harness and 1 to the light green wire. they're both on the old plug that went to the auto shifter.
Old Oct 11, 2009 | 12:13 PM
Car: 1989 iroc-z
ok thanks.
im gonna have to figure out where that connector is exactly since i bought the car with the t56 already in it but that shouldnt be hard.
im not sure when ill be able to get under the car next but ill be on here as soon as im done with it.
Old Oct 13, 2009 | 07:29 AM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
thanks for the info i had the same to questions
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
