Speedo operation Q ???
Old Oct 14, 2009 | 05:45 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Well, wifes 700R crapped in my 86 (her) TA, i removed the trans in favor of a 91 truck 700R and swapped tail housings, it has the metal sleeve and magnetic style speedo setup instead of gear driven on hers, can i splice the truck style plug in to get it to work or is there more PITA work to it than that?
Never ran into this problem before.
Old Oct 17, 2009 | 11:43 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: Speedo operation Q ???
Nobody have a clue?
Old Oct 17, 2009 | 02:24 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
yes you should be able to .. use the connector from the newer trans and wire it into the 86....it should be 2 wires anyways
Old Nov 2, 2009 | 11:30 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
I wonder how it will be, the original gear was a 2.73 and i swapped it to a 3.23, so if it has a 3.23 in the truck the trans cam out of it might be right.
Old Nov 2, 2009 | 05:05 PM
dyed's Avatar
Car: 84 Z/28
Transmission: 700R4 - rebuilt by me
Axle/Gears: 3.73 posi
Ok, it sounds like you're making this far harder than it needs to be. Reuse the old speedo parts, all of them. If you changed the rear end gear, you will need to change gears accordingly. I'm too lazy to type it all out, call if you want.
David
913 620 0963
Old Nov 5, 2009 | 08:25 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Well, then it should work i would hope. The problem is, the hook up for the trans am is not the same as the trans from the truck. I could nto swap it all out on the tail shaft since it had that sleeve i could not figure out how to remove...if you can even remove it.
Old Nov 5, 2009 | 09:48 PM
dyed's Avatar
Car: 84 Z/28
It can be removed. Look in the tech articles for pics but there is a little spring clip you need to fight with. Also, it is very nearly press fit, so... hammer time. Carefully.
Old Nov 5, 2009 | 10:42 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Well, if i can get the pig tail fro the truck and splice it, that is the way i will go, other than that, i will have my trans guy do it since it is his bag. He wont charge much if it is reall possible.
Old Nov 5, 2009 | 11:52 PM
dyed's Avatar
Car: 84 Z/28
Is the speedo in the car electronic? My 86 was mechanical. If electronic, they should be roughly interchangeable.
Old Nov 7, 2009 | 11:17 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Yea, it is electric.
Old Nov 7, 2009 | 11:22 PM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Weird my 86 is mechanical but its camaro.
Old Nov 7, 2009 | 11:48 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Trust me, i was baffled too when i got the car 8 years ago. I was like, WTF? My 89 RS has a mechanical but my 86 TA is electric????....i give...LOL.
Old Nov 8, 2009 | 07:03 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
"Birds" electric, 86 (IIRC)-92
Camaros, electric, 90-92
JamesC
Old Nov 8, 2009 | 10:17 AM
dyed's Avatar
Car: 84 Z/28
So, I would say, use the pickup and sleeve from the old tranny. Reluctor rings are generally the same for 700s.
Old Nov 9, 2009 | 02:17 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
JamesC
??? Wow, did not know that!
Fanatic1074
Oct 3, 2022 05:57 AM
Elephantismo
Feb 13, 2019 12:51 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
TrevinE
Sep 14, 2015 03:20 PM
