going 200c to th350 need help!!
Old Oct 16, 2009 | 06:27 PM
ranger77's Avatar
Car: 82 firebird
Transmission: i believe 200c
Axle/Gears: 3.43 Posi
Well as title said im going from a 200c to a th350 cause i hear its an easier set up. If anyone can post what will need to be altered/replaced when switching it would be very helpful. Ive heard if i went to a 700r4 i would need to buy alot.
If you can just point out what to need to be replaced on a 82 firebird with a 200c tranmission going to a th350 it would be very well appreciated.
I was thinking about something along the line of this http://pittsburgh.craigslist.org/pts/1386911280.html
ps. I searched alot of threads and didnt see a straight answer.
Old Oct 16, 2009 | 09:47 PM
sgt473's Avatar
Car: 87 Z28
Engine: LB9
Transmission: 4L60
Axle/Gears: 2:73
Re: going 200c to th350 need help!!
I think you'll find that the tail housing is to long. You need a short tail t350 .You'll need a modulator and a kick down cable and bracket. You may want to find a 350 c with lock up converter, coolant lines should work shifter may need some minor work not sure about the drive shaft . Hope this helps.
3rdgenparts
Exterior Parts for Sale
26
Apr 7, 2016 11:21 AM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
romcjr
Sep 17, 2015 05:18 PM
89newfun
Sep 16, 2015 09:28 AM
383cam
Sep 9, 2015 06:01 AM
