Differental fluid?
Car: 1991 Trans Am GTA
Engine: 350 tpi
Differental fluid?
hi i was going to change the fluid on my differental its a limited slip with 3.42 gears i wanted to know which fluid i should use to do it thanks!
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Differental fluid?
GL5 (80W90) and put in the GM posi additive (stuff really stinks)
If you want to use a synthetic, you can use 75W90 but I'd still put in the posi additive.
Capacity is around 2 quarts but buy 3 just in case it's slightly more.
Car: 87 IROC L98
Oil, yes. GM posi additive, maybe, and if not, they'll have something similar.
The posi additive is required if you have a real posi using clutches or cones. If you have a gov-lock system, the additive isn't required.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
GM’s limited slip additive is p/n 1052358. Your dealership will have it in stock.
JamesC
JamesC
Transmission: Pro-built 700R4
If flushing all the fluid with Royal Purple, is the additive still needed? From what I've read, RP has an additive in it that negates the requirement for the additive. Is this correct?
HoosierinWA
Oct 7, 2015 10:15 AM
