J&W Trans-x transmission treatment? help!
Car: 1989 camaro iroc-z28
Engine: 5.7L 350 TPI
Transmission: 700R4-shift kit, moderate stall
Axle/Gears: 3.27 Borg Warner
has anyone used J&W trans-x to clean and refurbish valves? i was advised to use it but have heard bad things about it. any prior experiences or suggestions would be very helpful!
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: J&W Trans-x transmission treatment? help!
One suggestion is sticking to one post instead of reposting same question by starting a new thread within 3 hours of posting the first. This is not a 24/7 helpline with operators standing by - you have to have patience and wait for a response from someone who may be able to help. Board moderators don't like double posts wasting server space, and the rest of us don't like reading the same question twice. Also, the
function works great!
function works great! Re: J&W Trans-x transmission treatment? help!
TransX additive is for (in 700r4's that is) when you lose reverse when its cold, but works fine when hot, and it is the low reverse seals that have gotten hard. This might fix it if it is the low/reverse seals. Problem is that this rarely happens in the 700R4's. I have seen it help out TH350's and mostly Ford C-6 transmissions. If it solves the problem, drive it a day or two more, then do a "complete" change of fluid as the TransX additive will keep making the seals grow and will "ruin" the transmission in a couple of weeks if it is left in. TransX is a "seal swell" just like the old carburetor cleaner of years ago. it swelled the seals that were accidently left in it in a short period of time.
well dooche bag no one said you had to read both post and if your gonna be sarcastic your reply isnt desired! i'm sorry you have no life to the point you feel like replying to threads with no intent of helping. also i'm sorry that the last time you got laid was in 1999 by a one armed hooker named steve..... go f*** yourself f***face!
Thank you "Pro Built" for the info that is one of the problems i've heard. i'm just wanting to make sure i make the right decision with the detergent or if its serious enough to rebuild? i'm in college and its hard to go without a car so i'm torn between the quick fix and the rebuild. thanks again! i cant stand guys like the one that replied before you.
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Well,
You posted a question, received good advice and got your answer.
I am locking this thread now.
In the future, please resist the urge to strike back to someone who gives you advice you do not wish to hear.
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
