Rear end question
Old Oct 31, 2009 | 04:23 PM
Americanmouse's Avatar
Car: 1988 IROC-Z28
Engine: L98(383tpi) modified
Transmission: 700R4 rebuilt
Axle/Gears: 3:73 10bolt rebuilt
Rear end question
I got a rear end of a 3rd gen firebird years ago. But other than it is a 3:73 gear with disc brakes I know nothing about it. I found a identification number on the housing which is #22522676. Can anyone provide any info on it for me, or direct me to a link that would provide info for me.
Thanks!
Old Oct 31, 2009 | 04:41 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Rear end question
No info of the number, but the following FAQ should provide some useful info:
https://www.thirdgen.org/forums/tran...-10-bolts.html
BTW, should the rear end be OE, it probably came from an 83-86 L69, the 305 HO car (Vin G).
JamesC
Old Oct 31, 2009 | 05:51 PM
Car: 1988 IROC-Z28
Thanks for the link!
Old Nov 14, 2009 | 10:31 PM
Justinlf16's Avatar
posi-limited slip or what how to test i've googled no real anser
im pretty sure i got burnt on buying a supposibley posi-rearend out of a 86 iroc z28 with the 350 tpi "he said" i seen the car it was a iroc z28. I bought the rearend he said was posi. The numbers are 2hd 176 1 i lookedit up it said 2:73, i think? Anyways when you turn the wheels out the ground you turn them one goes one way one goes the other way, anyone know what i have i tried finding the thread on here inestead of asking but i couldnt find it, thanks yall I have been to the forum that talks about the rearend i cant find how you test it?
Old Nov 14, 2009 | 11:15 PM
Justinlf16's Avatar
Re: posi-limited slip or what how to test i've googled no real anser
Old Nov 14, 2009 | 11:46 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
2HD = 1986 2.73 open diff. If it has 3.73 and a posi then it's not original. A previous owner could can changed anything. The only way to know for sure what's in the diff is to pull the cover and have a look.
Old Nov 15, 2009 | 12:01 AM
Justinlf16's Avatar
thanks steven for the info, and everyone else i tried to delete my post's above and i couldnt so i tried to edit that one post and just but question marks, but obviousley it put both of them on there, im thinking about just welding the spider gears now on the car hell with it lol.
Old Dec 11, 2013 | 12:26 PM
M3638's Avatar
Car: 1990 Iroc Convertible
"2HD = 1986 2.73 open diff. If it has 3.73 and a posi then it's not original. A previous owner could can changed anything. The only way to know for sure what's in the diff is to pull the cover and have a look."
Can anyone share a picture of each (inside the rear cover), limited slip and non limited slip? I'm in the process of buying one and don't want to run into the same problem. Thanks
Old Dec 11, 2013 | 12:32 PM
JamesC's Avatar
Check the FAQ I link to above.
JamesC
Old Dec 11, 2013 | 02:02 PM
M3638's Avatar
Woops,,, thanks.
Old Dec 11, 2013 | 02:36 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
If the tires turn in opposite directions you have an open rear, or a posi that needs rebuilt.
Old Dec 11, 2013 | 06:51 PM
Sojer's Avatar
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
well he lied about the 86 350 TPI
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
