4th Gen Rear End Swap U-Joint Problem
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
Hello,
I swapped in a 4th Gen rear end out of a 2000 Z28 into my 91 GTA. I went to connect the aluminum driveshaft and noticed there is about 1/4 to 3/8" play side to side in the U-Joint. The u-joint is brand new. Is this normal or is something incorrect?
Thanks!
Josh
Thanks!
Josh
Re: 4th Gen Rear End Swap U-Joint Problem
Is the aluminum drive shaft a factory part or is it after market? What u joints are in the shaft? The 4th gen rear end should have the 3R yoke. You might have a 1310 u joint in the drive shaft. Just a guess.
It is the factory aluminum driveshaft and I bought the U-Joint listed at Advance auto parts. Can I get a different U-Joint?
DO NOT run that. That is not normal in any way, shape or form. You got the wrong u-joint. I'm not sure if it takes a different u-joint for a steel vs aluminum shaft but I would try to get one for the model year that the driveshaft came from. It is possible that the u-joint is mislabled as well. Either way, take it back out and get the right one.
Thanks guys!
Well, I purchase the 1310 U-Joint.
Will this one work with my aluminum driveshaft:
http://www.summitracing.com/parts/PCN-235/
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
AkDrifted
Aug 17, 2015 07:45 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
