85 t/a trans pan torque specs
Old Nov 5, 2009 | 06:49 AM
thetaman85's Avatar
Car: 85 Firebird Trans Am
Engine: Rebuilt 305 Carb
Transmission: Built 700R4
Axle/Gears: The unfortunate Open Diff, 3.23
can anybody tell me what the torque specs are for the trans apn on my 85's automatic trans? it leaks and i want to torque them before i replace the gasket, only if necessary.
thanks
Old Nov 5, 2009 | 03:36 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: 85 t/a trans pan torque specs
They are very small bolts, so something just beyond hand tight is good, just like steel valve covers. If there is a torque spec, it will be measured in in-lbs.
Old Nov 5, 2009 | 04:10 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
105 inch pounds.
Old Nov 6, 2009 | 07:34 PM
Pro Built Automatics's Avatar
When using the cork and rubber gaskets, tighten to 65-70 inch pounds and tighten "once" only. With the Duraprene gasket tighten to 70-80 inch pounds. Add a pan magnet if you do not already have one. Most "so called" pan gasket leaks are not the pan gasket, but leaks from TV cable top hat seal, dipstick tube top hat seal, manual lever seal, or the speedometer seal.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
mizz0313
Aug 12, 2015 06:45 AM
Exxon Limited
Aug 9, 2015 08:13 PM
gwade12
Aug 8, 2015 08:17 AM
