10bolt
Old Nov 5, 2009 | 09:28 PM
kevin labrash's Avatar
10bolt
Just new to the site
Have 85 firebird 350 crate motor with 5 speed
Want to change rear end?
Was wondering will a 10 bolt out of a 70-81 trans am work?
Going to get frame connectors put in and going to use southside bars and new panhard bar.
Old Nov 5, 2009 | 09:44 PM
Iroc-Z28Man's Avatar
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
Re: 10bolt
Not a direct bolt in if that is what your looking for. the second gen rear ends don't have the places forthe LCAs and Torque arm. I would recomend if you are going to to that kind of fab work on it just do it to a 12 bolt or a 9inch ford not another 10 bolt. However a 10 bolt out of a Forth gen camaro or firebird would be a direct bolt in.
Old Nov 5, 2009 | 10:31 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 10bolt
First and second gen f-bodies used leaf springs. Third and fourth gens use a torque arm suspension. Although all the mount brackets for shocks, springs etc can easily be cut off the third gen diff and welded onto another diff, there's no easy way to attach the torque arm onto any other diff other than a 9" by using a special bracket available from Currie. A fourth gen diff isn't much stronger than a third gen diff and it's slightly wider. Your 85 will have 26 spline axles and the 1990+ f-body diffs have 28 spline axles. Other than that, they still have a weak 7-1/2 (7-5/8) ring gear.
Before trying to swap over some other diff, make sure it's close enough in width to a third gen diff.
If you search through the forums, you'll find the South Side bars are not recommended and most third gen owners find them as junk.
Old Nov 6, 2009 | 12:05 AM
Engine: 350TPI/ S50
Re: 10bolt
BMR actually makes a bracket for 12 bolts it's not designed to work with a third gen. i believe it's used for a torque arm conversion for first gens. But they do make a way to put stronger rear ends in to third gens, if you have fab skills you could make the same bracket if you want to put that kind of time and effort into it.
Old Nov 6, 2009 | 06:32 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 10bolt
Info in the following FAQ may prove useful:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Nov 16, 2009 | 07:53 PM
Re: 10bolt
How fast can you go with a 10 bolt rearend?
Old Nov 16, 2009 | 09:12 PM
big gear head's Avatar
Re: 10bolt
Which 10 bolt? There are at least 3 different 10 bolt rear ends. The only 3rd gen 10 bolt is the 7.5, and it isn't very strong.
AlkyIROC's Avatar
Car: 87 IROC L98
Re: 10bolt
I was somewhere in the mid to low 10's using a beefed up 10 bolt before finally switching to a 9". I installed a transbrake and knew the 10 bolt wouldn't take more than one transbrake hit so I changed the diff at the same time.
Linson
Nov 12, 2015 08:09 PM
formul8!!
Oct 8, 2004 03:42 AM
MrDude_1
Jul 28, 2004 12:58 PM
TAMECH
Feb 18, 2002 12:40 PM
