what thread size are the bolts that hold the cover on a 10bolt?
Old Jul 28, 2004 | 12:45 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i have a TA girdle.. i plan to just buy 10 studs and 10 nuts/washers to hold it on... but i need to know what thread size the bolts are.
id like to pick the bolts up on my way home from work tonight, so i cant just go under there, pull the top bolt, drive to the store and compare...
anyone know?
Old Jul 28, 2004 | 12:58 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
5/16"-18 x 1"
What you're talking about won't really work, unless you're going to put the nuts and washers on top of the cover; they won't go down into the counterbore. Yuck. Besides mostly defeating the girdle function.
A better thing to do would be to stop at Home Depot or the like, and pick up 10 Allen head bolts as described above. Then they'd at least sit down inside the holes, and somewhat brace the thing a little bit. 2 of the bolts are supposed to have a spacer washer that positively locates the cover on the flange.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
toronto formula
Nov 10, 2015 06:17 AM
Linson
Aug 21, 2015 02:12 PM
knight72
Aug 10, 2015 09:32 PM
