9 bolt questions
Old Nov 15, 2009 | 10:58 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
9 bolt questions
do you have to add posi add for the 9 bolt?
if the cones are not shimmed what kind of noise will it make?
Old Nov 17, 2009 | 09:49 AM
jamon8's Avatar
Engine: 350 tpi
Re: 9 bolt questions
anyone?
Old Nov 17, 2009 | 10:26 AM
big gear head's Avatar
Are you asking about the oil additive? You might get different answers for that, but my opinion is yes. It will pop and chatter when turning corners if you don't use the additive.
I don't understand the question about shimming the cones. What noise are you talking about?
Old Nov 17, 2009 | 10:42 AM
Stephen's Avatar
Car: 87 GTA
Since they are a cone style, not a clutch style, they shouldn't need it.
Some people do, some don't. My FSM didn't call for it, so I didn't put any in & it's quiet as ever.
Old Nov 17, 2009 | 11:22 AM
The Auburn usually requires 2 bottles of additive to get them to stop popping.
Old Nov 18, 2009 | 02:11 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Im with you. I shimmed mine tight, used no additive and have not heard a peep from my dif. I read up on her all over the place and heard yes and no to the additive question. One person made a good point awhile ago though. All the additive is there for is to allow the posi to slip going around corners. The way i see it, if you use the additive it will just slip easier and wear faster. Thats just how i see it though. This is only for the 9 bolts however since i have no experience with normal clutch type posi's
Old Nov 18, 2009 | 02:51 PM
Twin_Turbo's Avatar
My opinion is to not use it, the additive is a friction modifier used in clutch type LSDs to eliminate clutch hammering (which is partially caused by those preload springs), since ours use cones that rub into the cae, it's not really meant to spin and wear out since you can't replace the worn material like you can replace the clutch packs once they're worn out. Therefore you want them to grab and not spin under load.
84z96L31vortec
Aug 20, 2017 12:16 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
