A cable that located under the dashboard...
Old Nov 18, 2009 | 12:40 PM
engongam's Avatar
Car: 1991 Trans Am GTA
Engine: 502 Ram Jet
Transmission: TKO600-racing gears
Axle/Gears: 12 Bolt Moser-33"axles-3.91 ratio
I changed my transmission (700r4) to a tko600 but I can not remove the cable that runs from underneath the steering wheel to the center console... Does anyone know how to remove it? I guess there is a connector but I could not figure how to remove it out?
Old Nov 18, 2009 | 03:59 PM
Iroc-Z28Man's Avatar
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
Re: A cable that located under the dashboard...
I know the cable your talking about its i belive its for when the park lock so you can't take the car out of park unless the steering wheels is unlocked. there is no need for it in a manual car so i just cut it when i did my manual swap.
Old Nov 18, 2009 | 09:10 PM
engongam's Avatar
Engine: 502 Ram Jet
The reason that I want remove it safely is that I sold my old transmission to someone, and I want him to use the tranny with full capacity Do you know any way so that I can remove it safely?
Old Nov 18, 2009 | 09:17 PM
Engine: 350TPI/ S50
When i traced mine back, it look like to me that it would require ripping the entire steering colum apart, i for one wouldn't want to do that. But can i make a suggestion, you could offter to trade the entire the steering column in stead of taking it out of the column its self. i think that would be less evasive than trying to remove the cable from the column, to me doesn't seem that important.
Old Nov 18, 2009 | 10:05 PM
engongam's Avatar
Engine: 502 Ram Jet
Or.... I can just say thay I do not have that kind of cable which cause not to take the car out from park if the steering wheel is locked, so that I can cut the cable
Old Nov 18, 2009 | 11:16 PM
Engine: 350TPI/ S50
that also works. LoL.
Old Nov 20, 2009 | 04:39 AM
Pat Hall's Avatar
You don't have to rip the whole column apart to remove that cable. It just attaches to the base of the column with a couple of tiny screws. I can't remember if they're phillips head or hex head, but it's really easy to remove. If you undo the 2 big nuts that hold the column up under the dash and just swing it down a bit you can easily see and remove the little screws that hold that cable on.
Old Nov 20, 2009 | 10:59 AM
Engine: 350TPI/ S50
I couldn't find such screws. I'm not one for extra effort either. any way thanks for correcting me i didn't mean to misinform anyone i just pointed out what i say.
Old Nov 20, 2009 | 09:42 PM
Pat Hall's Avatar
No worries. It may not even be the same deal on all years and columns, but I did find removable screws for that cable on my 89's column. There's also a stud/nut deal that holds the cable to the inside of the firewall in front of the floor console down by the gas pedal.
wigmobile
Feb 26, 2025 02:56 PM
topteam54
Oct 6, 2015 12:21 AM
L0tuS
Oct 4, 2015 08:07 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
tonys91rs
Sep 2, 2015 07:07 PM
