over 70 mph car shakes through the tranny
Old Nov 23, 2009 | 02:39 PM
matthufham's Avatar
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
if i get over 70ish at first it gets a feeling of floating and then a constant vibration i feel in my shifter. i have a t-56 that didn't have issues before i swapped a new rear end in there the other day (which is when this shake started)
if i put the clutch in i still feel it shaking bad in the shifter. so it's not motor related and i doubt tranny related because like i said i just did the rear end swap
the car would shake before the swap but not anything like this, i had a slightly bent axle before.
so far to correct my vibration i've done the brakes (new cylinders, shoes, and drums)
checked driveshaft/ujoints (no play) can it be flipped 180 degrees and be unbalanced? i havent tried flipping it.
all bushings are good (panhard, torque arm, control arms) and all bolts are tight.
the new rear end is a 10 bolt 3rd gen 3.73 posi built 15k ago or something and i put 75 90 mobil 1 synthetic in it til it came out the fill hole.
i'm needing tires so i'll be checking the wheel balance soon, but any other clues you guys can mention?
Old Nov 23, 2009 | 04:23 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Re: over 70 mph car shakes through the tranny
Hmmm...sounds like a bad bearing somewhere in the rear end assembly. I'm no expert, though.
Old Nov 30, 2009 | 12:50 AM
matthufham's Avatar
Car: 90 z28
Transmission: t56
any more suggestions?
Old Nov 30, 2009 | 02:06 AM
livinforhim's Avatar
Car: 1990 Camaro RS
Engine: 3.1 V6
Transmission: 700-R4
I really don't think you'll get that improved much more. make sure your wheels are balanced and tire pressure's are all what there suppose to be. but it really seems to me that it is a suspension issue. my has done it for years now, there just old cars. unless you wanna shell out some money for and suspesion rebuild, new bushings make a huge diff thought. It wouldn't make a difference if your drive shaft was flipped, it still rotates the same direction regardless, as long as its ballanced. double check your new rearend. no bent axel, fluid levels good. that kinda stuff.
Old Nov 30, 2009 | 12:49 PM
PorkchopExpress's Avatar
You didn't mention what kind of T-56 you put in, but if it's one of the newer retrofits (so you can use the standard clutch and bellhousing along with mech. speedo), then it's roughly 2" longer than the 700-R4 or T-5.
This means your pinion angle could be off, which could cause the shaking.
http://www.carcraft.com/howto/91758/index.html
Old Nov 30, 2009 | 11:07 PM
matthufham's Avatar
Car: 90 z28
Transmission: t56
its a lt1 style. but it wasn't bad before the rear end swap, now it's terrible. i would think pinion would be the same since the torque arm is the same
BlueIroc-Z
Jun 9, 2019 03:22 AM
B_Dubya
Aug 26, 2015 05:09 PM
hokis
Aug 9, 2015 03:57 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
drathaar907
Aug 6, 2015 04:20 PM
