Hard to get into 1st and 2nd gear
Old Nov 24, 2009 | 07:38 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I've noticed with my T56 lately that it seems like it's hard to get it into first and second gear. I dont know if it's gotten worse or whether it's always been like this as I've been learning to drive it and my driving style has evolved over the past 6 months or so.
But it's hard to get it into first sometimes at a stop. If I throw it in neutral and coast to a stop, sometimes it wont really go in once I'm ready to go again. If I slide it into first as Im rolling to the stop, i can feel it click in, and then once I've stopped I can throw it in neutral, and then throw it right back in just fine. And I've just sort of habitually done it this way 95 percent of the time.
Im guessing this is the synchros, since I would guess the input shaft side of the trans isnt really moving and the driveshaft side is still moving as the car is moving, and the dog teeth line up and it notches right in place as soon as it all lines up. As long as the car doesnt move between the last time first was engaged, it goes right back in just fine. The question I have is... Is this normal? Every time it didnt want to go in I could just throw it back into 2nd, and then put it back into first and it usually will notch itself in at that point. But I wonder if this is a sign of some other larger problem?
The hydraulics are new, btw. Pre-bled brand new GM hydraulics that are only a few months old.
Old Nov 24, 2009 | 09:06 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: Hard to get into 1st and 2nd gear
What fluid do you run and how old is it? How long ago were the synchros replaced?
Old Nov 24, 2009 | 11:36 PM
Car: 1992 Camaro RS
Synchros have never been replaced as far as I know. It's out of a 94 TA with a lot of hard miles on it. I dont expect it to last forever.
It has ATF in it. Dexron III I think? It was 6 months ago when I filled it. Cant remember how much I put in it, but I'm pretty sure I put in the amount that was supposed to be in there? I remember checking at the time as Im fairly thorough.
You think maybe I should try putting gear oil in it?
Old Nov 25, 2009 | 07:42 AM
remltr's Avatar
Car: Bone stock 1989 Iroc T-Top,1991 Z28
Engine: 5.7, Carbed 383
Transmission: 700r4, T-56
Doesn't call for gear oil. Sounds like syncros. Try when it doesn't go in, let out the clutch in neutral, push it back in then engage first. It should help until you need a rebuild.
Azrael91966669
25
Jun 20, 2017 04:04 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
gixxer92
Sep 1, 2015 04:32 PM
dhonda200
Aug 11, 2015 11:50 PM
