rear end??
Old Nov 29, 2009 | 10:02 PM
Adrenaline91RS's Avatar
Car: 1991 Chevy Camaro RS
Engine: 350 Crate Motor
Axle/Gears: 9-bolt Limited Slip
rear end??
is there a difference between 3rd gen and 4th gen rear ends, or will a 4th gen rear bolt right in?
Old Nov 29, 2009 | 10:22 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: rear end??
4th gen diff will bolt right in but it's slightly wider. There's no strength difference between a fourth gen diff and the 10 bolt that should be in your 91. If you do have a 9 bolt under your car, it's not original.
Old Nov 29, 2009 | 10:46 PM
Re: rear end??
i know that the 9 bolt isnt stock but right now i have wheel spacers on it to fit my tires, and would like to put a wider rear in so can get rid of the wheel spacers......
which would be stronger though the 9 bolt with the wheel spacers, or a 10 bolt?
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
