vibration from 70-80
Old Dec 11, 2009 | 04:03 PM
91 camaro rs's Avatar
Car: 91 rs
Engine: 305tbi
Axle/Gears: 3.27 9bolt
took the camaro out to stretch her legs today. noticed a pretty harsh vibration fro about 72-80. thinking the driveshaft. any thoughts?
Old Dec 11, 2009 | 09:28 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: vibration from 70-80
Have the wheels spin balanced, and INSIST they spin them up to 70mph. Most shops won't do it - they look at you like you'll never go that fast - then I ask them how fast their wife drives on the 4-lane - then they giggle and say "I see your point", and do it. They usually only spin to about 35mph, which is useless - I always ,ake them spin it to 70mph, or I go on down the road.
If that doesn't work, then maybe look into DS.
Old Dec 12, 2009 | 08:01 AM
Blind Driver's Avatar
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
I would check the driveline. Driveshaft, u-joints and yokes being the first on my list.
Old Dec 20, 2009 | 08:06 PM
hotbird89's Avatar
Car: 90 Trans Am
Engine: 5.0 TPI- slightly modified...
Transmission: Modified 700-R4
Axle/Gears: 10 bolt 3.23 eaton posi moser shaft
I had the same problem. I put the old girl up ona lift, and grabbed drive shaft and gave her a shake. Lo and behold, it moved, but not the U-joint. The entire yolk moved. The original limited slip diff is still in there (not for long though).......
Old Dec 23, 2009 | 02:54 PM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
had this problem also, solution? my tranny mount!
69GTOby
Apr 18, 2016 02:34 PM
sac92transam
Oct 7, 2015 02:31 PM
roysatikas
Sep 22, 2015 08:15 PM
BWilcox
Sep 20, 2015 12:19 PM
InfinityShade
Sep 18, 2015 08:32 PM
