T5 noise
Old Dec 23, 2009 | 05:10 PM
tyler86z28's Avatar
Car: 1986 Camaro Z28
Engine: 355 4 bolt 4bbl
Transmission: T-5 manual
Axle/Gears: 3.73 posi.
T5 noise
My T5 tranny is whining in Neutral with the clutch released and when clutch is pressed down, it turns into a chattering sound. Could this be the throw-out bearing? It also whines in 1-2-3, but I hear that's pretty normal.
Old Dec 23, 2009 | 06:54 PM
HankL69's Avatar
Car: 85 IROC / 69 Firebird convertible
Engine: 5.0 / 350
Transmission: t-5 / WC t-5
Axle/Gears: 3.27 / 3.08
Re: T5 noise
You normally hear some noise from a t-5 in neutral but only if you are listening for it. I'm not sure just how much whining you are hearing. However, when you push the clutch in there should not be any "chattering". My guess would be the throw out bearing.
Old Dec 23, 2009 | 07:11 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: T5 noise
when was the last time you checked or change the trans fluid???
My T5 made noise in 3rd for a long time, many years.
Then one day it got stuck in 4th and would not come out.
Had to drive home in 4th only. Sounds hard ehy?
Nope cause I thought I got it fixed and it then got stuck in 5th.
Now startin off from a dead stop in 5th to get home was H-A-R-D
but it can be done.
Old Dec 23, 2009 | 07:12 PM
tyler86z28's Avatar
Re: T5 noise
Yeah, my T5 sounds like an 8-71 supercharger in neutral. It's pretty loud and not normal.
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
Randomtask2
Sep 7, 2015 05:06 PM
