Rubber plug
Old Dec 13, 2009 | 06:22 PM
IROCU2's Avatar
Car: 1987 IROC-Z
Engine: 5.7 TPI
Transmission: 700-R4
Rubber plug
Do anyone know where I can get the rubber plug on the back of the Borg Warner 9 Bolt Rearend cover?
Old Dec 14, 2009 | 07:13 AM
big gear head's Avatar
Re: Rubber plug
It's probably the same as the one used in Jeeps. You might try a Chrysler dealer.
Old Dec 14, 2009 | 12:29 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Rubber plug
Better solution is to tap it for a tapered pipe plug.
Old Dec 14, 2009 | 03:46 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Re: Rubber plug
Yeah, the dealer should be able to help you out. Or, what I would try first, is I know that in some parts stores "Help" section, they have plugs labeled for Chrysler, but looks awfully close to the 9 bolt plug. I think it would be a lot cheaper if you could find one of those and it fits.
Old Dec 14, 2009 | 06:14 PM
IROCU2's Avatar
Car: 1987 IROC-Z
Engine: 5.7 TPI
Re: Rubber plug
Thanks all for your help. I did not think of the help section. I will check and let everyone know my findings.
Old Apr 26, 2011 | 07:17 PM
beaner104's Avatar
Re: Rubber plug
I'm in the same spot that you were. My plug was so old that when I took it out it broke into pieces. What did you find out and where did you have to get the replacement Plug.. Thank for the help.
Old Apr 27, 2011 | 12:53 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Rubber plug
Summit's web allows you to search parts by o.d.
I had to locate a valve cover grommet that way.
Old Apr 27, 2011 | 01:48 AM
BlackRS839's Avatar
Car: 1990 Chevy Camaro RS
Engine: SBC 305 TBI, soon to be 383
Axle/Gears: 8HL 3.42:1
Re: Rubber plug
Tom91 is correct about the "help" brand also known as motormite. Places like autozone may not have them there, or even know how to look them up, but im about 95% sure they make the plug you need, Try going to a less commercial parts store that supplies mainly to repair shops, as they will have a better selection and more than likely several parts experts who have been sourcing hard to find parts for years.
Old May 6, 2011 | 08:27 AM
IROCU2's Avatar
Car: 1987 IROC-Z
Engine: 5.7 TPI
Re: Rubber plug
beaner104, Funny thing is I got the plug from my friend that works at Jiffy Lube. Yeah I know Jiffy Lube of all places.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
