T56 VSS and SGI-5 rev C questions
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
I've looked but haven't found any clear answers to these questions:
1 - What type of signal does the T56 VSS output? Sine? Square? Frequency (PPM)? Voltage? The skulte site says 17 PPM but that seems WAYYY too low.
2 - Skulte also says Autometer makes electrical speedos that will accept the VSS speed sensor directly........do they? Autometer part #5889?
3 - Will the SGI-5 box be needed to run the autometer gauge?
I've read all about the gauge and SGI-5 box, but am just looking for some straight answers. Thanks guys.
Rob
Rob
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: T56 VSS and SGI-5 rev C questions
The VSS is a 17 pulse per rev (17tooth reluctor wheel) which gives you anywhere from 25,000 to 40,000 pulses per mile depending on your gearing/tires.
Autometer Electrical Speedo's will accept and calibrate directly to the T56 VSS signal
The pre-90 TPI ECMs can't directly accept the T56 VSS signal, so the dakota (or similar ) box would be required if you need that.
JTR had a decent writeup on the T56 VSS signal and conversions, but I've lost the link right now.
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Car: '91 LS6/T56/9"
Engine: LS6
Very cool. I just picked up the Autometer 5889 speedo for $73 shipped to my door on craigslist!
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
