Any pic of B&M-30299 Installed!!!
Old Dec 18, 2009 | 12:19 PM
355sbc's Avatar
Car: 1989 camaro
Engine: 350 sbc
Transmission: 9" tail th350 B&M stage 2 shift kit
Axle/Gears: 4.10
I have a th350 9" tailshaft and was wondering if anyone that installed this kit on there car could get me some Pics of it on the car.
From what I searched I will still be able to use the stock crossmember
with this kit.
Old Dec 18, 2009 | 01:51 PM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
Re: Any pic of B&M-30299 Installed!!!
I used that kit. I did not work with the stock crosmember. I had to mod my crossmember to make it work. After reading a couple other posts, your 9" tail may work with the stocker, but I can tell you the shorter 6" tail which I have will not work. But that kit has everything else you need though.
Old Dec 19, 2009 | 12:31 PM
355sbc's Avatar
Car: 1989 camaro
Engine: 350 sbc
Axle/Gears: 4.10
Thanks for the reply. Is there any way you could get pics of yours installed.
I also read a few post with different people saying the 9" tail shaft will work with the stock cross member with an adapter that comes with the kit. did you get some kind of adapter with your kit.
Old Dec 19, 2009 | 04:30 PM
dellman83Z's Avatar
Its in storage right now, so no pics available until spring. My kit did not come with anything for the crossmember. I basically made a small thick bracket that extends from the stock hole for the mount stud out about an inch and a half with another hole. Works great so far.
Old Dec 19, 2009 | 04:51 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
the hurst kit doesn't have the crossmember piece, the B&M does and it works fine. I used it on an old buildup now i made a custom piece since i'm running a th400
Old Dec 20, 2009 | 03:58 PM
355sbc's Avatar
Car: 1989 camaro
Engine: 350 sbc
Axle/Gears: 4.10
Thanks for the replys ill just go with the B&M kit whenever i get some money and let you know how it comes out.
Old Dec 20, 2009 | 06:33 PM
blue85305's Avatar
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
i have also used the b&m kit(no pics sorry) and the 9" tailshaft 350 will work with the stock crossmember.
Old Dec 20, 2009 | 09:03 PM
elano's Avatar
Car: 86 IROC-Z, 82 z28
Engine: 383 Stroker
Transmission: TH-350
Axle/Gears: 3.73 Torsen, 4.56 Auburn
Why would the tailhousing matter? The mount should be in the same location, only different driveshaft lengths right?
Old Dec 20, 2009 | 09:36 PM
blue85305's Avatar
Car: 1984 camaro
Axle/Gears: 3:42
correct, i was just saying that i used a 9" tailshaft model because that was specifically the op's question. according to the dimensions on the tci website it doesn't matter whether its 6" or 9".
http://www.tciauto.com/Products/TechInfo/trans_dims.asp
Old Dec 21, 2009 | 09:23 AM
dellman83Z's Avatar
I feel a little ripped off, the b & m kit I had didnt have that crossmember piece. That would have made my life a little easier last year.
Old Dec 25, 2009 | 01:37 AM
elano's Avatar
Engine: 383 Stroker
This is mine.
Old Dec 26, 2009 | 12:49 AM
355sbc's Avatar
Car: 1989 camaro
Engine: 350 sbc
Axle/Gears: 4.10
Thanks for the pic elano!!! It looks like there is lots of room to mod cross member for 3" dual exhaust. Im gonna buy this kit for sure, and now have plans to modify the cross member for true dual 3".
Old Apr 12, 2014 | 09:52 PM
sniper214's Avatar
Car: 91 Camaro RS
This is mine.
How did you mount your torque arm? I am missing a part for the torque arm... Thanks
Vintageracer
Jan 10, 2020 05:33 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
aaron7
Aug 17, 2016 06:02 PM
mustangman65_79
Aug 13, 2015 07:36 AM
sonu1975
Aug 11, 2015 08:38 AM
