t56 swap
Old Dec 23, 2009 | 10:16 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
t56 swap
well, today, I lost 3rd and 4th gear on my way to pick up some new parts, so needless to say I need a new trans, and I figured I'd upgrade to a T56. I'm looking at a LT1 t56 parts car, what parts will I need that the parts car won't have?
I know I'll need a swap crossmember, and a new console top plate from a five speed, anything else?
Thanks-
Eric
Old Dec 23, 2009 | 11:04 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: t56 swap
ECM reprogramming for Manual Trans.
Dakota box or ECM mods for VSS.
Possibly Correct TQ-arm bushing
Old Dec 23, 2009 | 11:23 PM
ericjon262's Avatar
Re: t56 swap
I plan to swap the engine and trans together (the LT1 T56 car was wrecked) would I still need the ecm reprogrammed?
When did the torque arm bushing change? the car getting the engine and trans is a 91, so it probably has the correct bushing right?
Thanks for your help-
Eric
Old Dec 24, 2009 | 01:22 AM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
Re: t56 swap
The thread I just started may be helpful.
https://www.thirdgen.org/forums/tran...ml#post4380434
Old Dec 27, 2009 | 02:02 PM
ericjon262's Avatar
Re: t56 swap
Still needing to know,
would I still need the ecm reprogrammed? I plan to swap the engine and trans, not just the trans.
and if my 91 and the 94 T56 would have the same torque arm bushing?
also, would an Ls7 clutch fit an LT1 T56 combo?
Eric
Old Dec 27, 2009 | 02:19 PM
85MikeTPI's Avatar
Re: t56 swap
Not for the trans, but purhaps for something else.. Post your questions in the Engine Swap forum..
Possible, but you need to check since there were variations.
No.
Old Dec 27, 2009 | 10:22 PM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
Re: t56 swap
you will probably just have to have the ECM to remove any vehicle ani theft and emissions. Nothing to do with the transmission swap. do a search on the topic that swap has been well documented.
AussiePr0nCar
Mar 6, 2020 04:04 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
19irocz85
Aug 30, 2015 10:03 PM
19irocz85
Aug 26, 2015 07:54 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
