"Thud" from rear end?
Old Dec 31, 2009 | 04:45 AM
tpi305's Avatar
Car: 1986 Iroc-Z, 1980 Cadillac Eldorado
Engine: Iroc- 5.0, Caddy-5.7
Hey everyone. Whenever I take off and give more throttle than what it takes for a fairly slow start, I get a kind of almost "bang" from what sounds/feels like the rear end area. It will also do it going into second at wot. I went underneath and found a very small amount of play in the drive shaft. Not a whole lot, but some. Could this be my u joints? Some people say a bit of play is ok, some say that no play is ok, so I'm not sure. This is my first rwd car. I'm hoping it's not my differential. It's a 1986 Iroc-Z with 3.23 posi....or limited slip... Thanks everyone.
Well for one I could have not been an idiot and changed the fluid before I made this post, but oh well. I'll try to do that tomorrow maybe.
Old Dec 31, 2009 | 06:38 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: "Thud" from rear end?
Check the transmission mount.
JamesC
Old Dec 31, 2009 | 06:51 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
i agree with JamesC , also take a look at the panhard bar . i had the track brace/panhard bar mounting bolts ( all 3 back out and fall away ) . good luck .
Old Dec 31, 2009 | 03:30 PM
Drew's Avatar
JamesC
Didn't even get past the second sentence and I was thinking the same thing. Use a Polyurethane mount and never worry about it again.
Old Jan 4, 2010 | 09:32 PM
tpi305's Avatar
Thanks guys. Now that you guys suggested the tranny mount, I've noticed that it does feel like it's coming from that area lol. Thanks! I still did the differential though, it needed to be done.
I've been planning on purchasing a core 700R4 and rebuilding it, as I've wanted to learn. That way I will still have mine just in case the rebuild doesn't work out. What would be the consequences of leaving it till then? This could be months...
Old Jan 5, 2010 | 06:22 AM
JamesC's Avatar
Swapping the mount out will hardly take as long as jacking the car up. No reason really not to replace. From the tech board:
https://www.thirdgen.org/trannymount
JamesC
Old Jan 5, 2010 | 06:38 AM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Tranny Mount poly ! Made by energy suspension, under $20...
Old Jan 5, 2010 | 06:46 AM
marekdennhardt's Avatar
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
I can give you detailed instructions on how to change the tranny mount. As I removed / reinstalled the cross member about 3 or 4 times during my restoration. And you can email me if you need help. I have my email account hooked to my blackberry phone, so I can give you an almost immeditate answer.
This upgrade should only take 30 mins max
Old Jan 5, 2010 | 04:19 PM
Drew's Avatar
JamesC
I don't know, the guy that wrote that article sounds a little iffy.
Old Jan 5, 2010 | 04:44 PM
C-Titan's Avatar
Car: 91 Z-28
Engine: 360TPI
Transmission: PA Racing 700r4
Axle/Gears: 3:73
^^^^ I've heard the same thing.... haha
Old Jan 5, 2010 | 04:56 PM
flu_by_u's Avatar
Car: 1989 Firebird Formula
Engine: 350 5.7L TPI
Definitely go with the poly. I replaced my rubber one twice already. I finally got smart and went to the poly, haven't had problems since.
Old Jan 5, 2010 | 05:20 PM
Drew's Avatar
One thing I'd add to that article, the Energy Suspension transmission mount comes with a preload plate. In some circumstances that plate increases the height of the transmission just far enough to create interference. Even though the instructions specifically state not to use the mount without the plate, it works just fine and can correct problems.
Old Mar 14, 2010 | 03:01 PM
88camaroluvr's Avatar
What are the torque specs for those bolts? Both trans connecting bolts and crossmember bolt. Thanks, I'm going to do this sometime during the week.
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
