8.5 rear swap
Old Mar 12, 2010 | 03:53 PM
SierraSR25's Avatar
Car: 1988 Firebird
Engine: 355
Axle/Gears: Moser axles, 342 gears
8.5 rear swap
I have a stock 7.5 rear in my 88 firebird that is close to the end of its life. I'm takin the car off the road so i can do whatever i want to it for the track. What would be involved in swapping an 8.5 rear other than ladder bars and weldin new brackets on? Any tips? thanks
Old Mar 12, 2010 | 07:21 PM
big gear head's Avatar
Re: 8.5 rear swap
Ladder bars should do it. Removing the spring perches, shock mounts and panard bar brackets and welding them on the new rear end will make the installation easier.
Old Mar 13, 2010 | 05:56 PM
SierraSR25's Avatar
Car: 1988 Firebird
Engine: 355
Re: 8.5 rear swap
Do i need to put a full frame in the car to weld a crossmember to for the ladder bars?
Old Mar 14, 2010 | 01:47 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 8.5 rear swap
The crossmember needs to be attached firmly to something. It's possible to plate the rocker panels and weld a crossmember directly to them. Years ago when I had ladder bars, I welded the crossmember between the custom made SFC.
Old Mar 14, 2010 | 03:35 PM
Re: 8.5 rear swap
Sub frame connectors should be installed at least.
1992rs/ss
Jan 31, 2025 05:10 PM
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
E Rod
Aug 28, 2015 05:17 AM
