700r4 issues
Old Jan 5, 2010 | 08:43 PM
macurtis's Avatar
Car: 1986 Z28 camaro
Engine: 350 bored .60 over
Transmission: t5
Axle/Gears: GM posi with 3.73 gears
700r4 issues
86 z28 stock was 305, swapped to a 350 mildly rebuilt and .60 over. I was having problems with tranny before shift kit install, waiting too long to shift etc. installed shift kit hoping this would solve problem. Now first gear will go to 6500 rpms, and wont shift til i let off at 6500. second gear feels like its slipping? i live in midwest and it feels like the wheels are breaking loose on top of ice in second gear. but they are not. nice hard shift into third. anybody have any help for me would be greatly appreciated.
Old Jan 5, 2010 | 08:50 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Re: 700r4 issues
Adjust the detent cable. Read my post below. You kight have to shove the detent cable forward thru the bracket.
Old Jan 5, 2010 | 09:25 PM
macurtis's Avatar
Transmission: t5
Re: 700r4 issues
ok did this cable all the way in and cable all the way out( small adjustments at a time) and it doesn't seem to make a difference....any other ideas or maybe bracket is not the correct distance from the tv bubble on carb linkages
a. Push in the Adjust Tab and retract the Slider in the direction shown in Figure 3.
b. Without allowing the Slider to move, pull the cable until it stops and measure from the mounting bracket to the cable end. Add 3/16" to this measurement and that will determine the ADJUSTER MOUNTING POINT distance at full throttle (WOT).
c. Also note in Figure 2 that the distance from the throttle shaft to the cable end is referenced. This distance must be between 1 7/64" and 1 1/8"! The cable end mounting point should follow a 78° arc between closed throttle and WOT in order to achieve the proper amount of pull on the cable.
i used this figure and the first measurement is 4 11/16" so my WOT should be 5" from bracket, but mine is 5 3/4" could this be the issue and if so how do i correct this?.......thanks
jklein337
Sep 19, 2018 06:23 PM
TheTraut88
Sep 7, 2015 05:22 PM
Americanmouse
Sep 7, 2015 12:10 PM
greenyone
Sep 2, 2015 03:39 PM
someone972
Aug 30, 2015 12:52 AM
