two bolt or three bolt tailshaft
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
i got a new transmission and it has a tailshaft with only 2 bolt holes for the torque arm.
do i need to swap the tailshaft?
the guy said that they came both ways and the transmission came off a 86 tbi camaro
help
help
Car: 85 Camaro IROC
Engine: 5.7 TPI
Re: two bolt or three bolt tailshaft
i assumed it was TBI because i asked him if it was TPI and he said no.
i was going to take the TV cable bracket off the car if it was.
i guess that means it was carbed then.
i ended up swapping the tailshaft.
the "new" trans had a cover on the main shaft that looked like it was pressed on after the speedo gear.
i wasnt able to remove it, but i swapped the driven gears in the tail shafts so i will at least have the same gear ratio in the trans that it came with.
i will look up the gear ratios i need and maybe swap the driven gear if i need to but does anyone know what the cover i am talking about is?
I couldnt pull it off and it wasnt threaded that i could tell and i didnt want to bugger it up.
Car: 85 Camaro IROC
Engine: 5.7 TPI
hmm.
well either way, i now have the speedo gears set up and the tailshafts swapped over.
my ratio is off by exactly 1.25 if i am correct.
i think the new trans was set up for a 26" tired car with 2.73 rear gears, it has blue drive and driven gears.
so it looks like i need a ratio adapter, because to get it correct, i would need a 48 tooth driven gear... or a different drive gear, which i cannot seem to be able to remove.
any ideas?
any ideas?
Numbah-1
Sep 12, 2015 08:57 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
